Double sided frame
Double sided frame
Postby fusionframer » Fri Oct 19, 2018 8:30 am
I was asked to frame this which had a print on each side of the paper. They wanted it to be able to switch the painting easily.
I used rose and hollis a820. First, i cut the mounts and glass, then measured the thickness of the sandwich. I then ran the moulding through my thicknesser until i had the right rebate depth to fit the sandwich when gluing the 2 frames together.
Made and painted frames, glued with glass etc in and clamped then tidied the join to hide it.
The issue was that to make it properly meant no fittings to hang, so made a base that it just slots into. The groove is 12 degrees and i fitted so felt to protect the frame. So you just lift it out, turn and push back in. The base makes it very stable.
www.fusionframing.co.uk
fusionframer
Interests: framing
Mainline Strathdon
Re: Double sided frame
Postby Steve N » Thu Oct 25, 2018 8:12 am
Nice job Nick :clap:
"Just because you seen it on the internet, does not make it true or right" -Abraham Lincoln
Postby Not your average framer » Thu Oct 25, 2018 9:44 am
Yes a very nice job and an innovative solution. Also not one of the easiest things to do, when it comes to running something relatively thin through a planner thicknesser and getting a perfect result when you have to match up and join all the bits. An excellent and very professional outcome.
:clap: :clap: :clap:
Postby poliopete » Thu Oct 25, 2018 2:30 pm
10 out 10 for ingenuity :clap: :clap: :clap:
You should feel very proud of the outcome :D
poliopete
Return to The Good, The Bad, And The Ugly
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
