Page 1 of 3
The Christmas Big'un.
Posted: Tue 29 Jan, 2019 5:45 pm
Frame to fit a 7' x 5' 2" canvas. :D
First step: Make the liner. Rose&Hollis A279. I widened the rebate on my routing table. Big canvases need lots of elbow room.
As it turned out, it was a bit out of square and just fiited. I didn't have the painting on the plot, the guy was still working on it
and no room anyway.....
You will see I had to build extensions to the table to accommodate the thing. I had to commandeer the front of the shop as it was
too big for the workshop. I don't usually like doing 'mucky' work in the shop, hence the dust sheets. I did manage to underpin the liner
but added steel 'L plates ' on the corners.
Re: The Christmas Big'un.
Posted: Tue 29 Jan, 2019 5:51 pm
Stage 2. Build the core of the frame. R&H A138. Once the liner is made the size is set and the important thing to establish
when multi-stacking is the differential between the long and short sides. This is a constant.
I didn't underpin this moulding. I put a biscuit slot in each corner and cross-nailed them. The webbing strap was a must as was
my newly bought spring-clamp set. Very old school. :P
Posted: Tue 29 Jan, 2019 5:55 pm
Further corner reinforcement. At this point I had to flip the beast over, which was probably the most problematic thing
of the whole job. :roll:
Posted: Tue 29 Jan, 2019 7:06 pm
by poliopete
So far so good :clap: :clap:
What device do you use to tighten the webbing?
Posted: Tue 29 Jan, 2019 8:57 pm
A big spanner. :D
Posted: Tue 29 Jan, 2019 9:13 pm
by poliopete
I am a little slow at times, but "a big spanner" :?: jes nas compre par :? . Do you mean as a tourniquet or some such?
Posted: Wed 30 Jan, 2019 11:57 am
:P
These are brilliant. Unfortunately no longer made. :(
Posted: Wed 30 Jan, 2019 12:01 pm
Next.....
A small reeded moulding fitted on the inside. I ran up a section of pine to form a 'bridging' piece under the rebate of the
bigger moulding.
Posted: Wed 30 Jan, 2019 12:12 pm
Now the tricky part......
Trying to join an 8' x 6' frame for the outer moulding was a bit too much. So I fixed each rail individually. The corner joints don't
need to be especially strong as the strength of the whole frame is in the middle moulding. Took a bit of faffing about to get the rails the
right length. I assembled the four rails 'dry' with the aid of the spring clamps and the removed one at a time a glued them all the way
along. Nailed though into the middle moulding.
Posted: Wed 30 Jan, 2019 12:20 pm
Had to extend the back to swallow most of the depth of the canvas. For this I used a square moulding with the rebate ripped off
and another smaller one with the outer edge chamfered.
The two short sides have a piece of PSE pine glued to the back for the hanging cleats.
Posted: Wed 30 Jan, 2019 12:37 pm
The bare frame completed. I added a few small blocks as strengtheners. Getting heavy at this stage. :?
Posted: Wed 30 Jan, 2019 12:40 pm
Posted: Wed 30 Jan, 2019 12:46 pm
Now to try to flip it over. I couldn't do it on the table as not enough ceiling clearance. So I had to do a three-point turn
on the floor. This had to be done very carefully. Helps if you have arms like a gibbon. :lol:
Posted: Wed 30 Jan, 2019 12:49 pm
While the main frame is off the table, time to finish the liner. All 28+ feet of it. :P Six processes, so that like doing one coat
on a piece nearly 180ft long.
Grain filled with polyfilla, two coats of ripple paint to prime and then two coats of 50/50 Titanium White/Buff acrylic.
When dry a toning coat of dilute Raw Umber.
Posted: Wed 30 Jan, 2019 1:57 pm
by Steve N
Following this, love the step by step technique, well done sir :nod:
Posted: Wed 30 Jan, 2019 3:08 pm
by poliopete
Absolutely love it :lol: much more entertaining than "Silent Witness"
Hats off to prospero :clap: :clap:
Can't wait for the next installment.
Posted: Wed 30 Jan, 2019 3:11 pm
(didn't have to wait long Peter. :lol: )
Now for the mucky part.....
Frame is to be black with gold sections. Frame all prepped and any holes filled and sanded.
Building up the black......
Posted: Wed 30 Jan, 2019 3:14 pm
All done and surprisingly zero paint on the walls.... :D
Posted: Wed 30 Jan, 2019 3:19 pm
The un-gold parts masked off and the parts to be gilded coated with Red Oxide acrylic.
Posted: Wed 30 Jan, 2019 3:23 pm
All the gilding applied. Bronze Powder (2.5 Gold) mixed with varnish.
