V Groove blades
V Groove blades
Postby ChrisG » Fri Jul 17, 2015 12:00 pm
I am finding that after cutting a relatively small number of V grooves even with a new blade and the groove is no longer clean. The same blade cuts the bevel and straight cuts without problem. I imagine that V groove only uses the very tip of the blade which wears quickly?
ChrisG
Organisation: Hampshire Framing
Interests: Labradors
Lion Pictureframing Sipplies
Re: V Groove blades
Postby jmdwilson » Fri Jul 17, 2015 1:04 pm
When my machine was set up I was told you need to change the blade after every v-groove done. ie one per mount.
jmdwilson
Organisation: Surrey Framers
Interests: Art, Sports
Re: V Groove blades
Postby Graysalchemy » Fri Jul 17, 2015 1:36 pm
What mount cutter is It. IMHO its no different to cutting all the way through and into the sacrificial piece under the mount.
Organisation: AIL
Interests: Picture framing and brewing
Re: V Groove blades
Postby ChrisG » Fri Jul 17, 2015 6:30 pm
Gunnar F1 Hybrid.
It's possible to 'clean' the groove with a scalpel blade but that's a bit of pain.
ChrisG
Re: V Groove blades
Postby Roboframer » Fri Jul 17, 2015 8:38 pm
Does it still cut normal openings OK after cutting V grooves? If so it could be the mount board or the calibration.
Back behind the velvet rope, Ladies.
Organisation: Angmering Framing & Stitches
Interests: Cooking, drawing.
Re: V Groove blades
Postby yorkframing » Tue Jul 21, 2015 7:59 am
I cut hundreds of V-Grooves and yes you do not get many to a blade.
I am cutting black core with a white face, I was getting 12 cuts per blade but then a new batch of board arrived, slightly different from the same supplier and I now only get 6 cuts per blade.
The main issue I find is a blunt blade drags the surface of the board at the corners, when cutting all the way through, there is more board to support the surface hence why v-grooves need sharper blades.
I always cut all the v-grooves I can first, then with the same blade cut the openings, that way you do not blunt the blade doing openings in between v-grooves.
Hope this helps
Steve
yorkframing
Organisation: York Framing Studio
Interests: Photography & Astronomy
Return to Technology - CMC's Computers Etc
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
