Any one reasonably clued up on Valiani Settings etc.
Ed209
Just wonder if there is anyone on here that I can ask questions about my Mat Pro Ultra 150 BC
Re: Any one reasonably clued up on Valiani Settings etc.
what's the problem
Ed209
Ed209
Grey EVO head over cut from Left hand clamp direction undercut from bottom clamp direction
Was on LT mode
Not sure what the difference is between the Linear modes
Was on LT mode
If you press F1, while your curser is over a buttom, then the help file will pop up with info for that section on page 120 (in title bar of Adobe Acrobat Reader) or page 113 on the page of the help file, you will fine the info regarding external cutting modes
Around mode: All the external cuts are made going around each individual mountboard. See fig.36
Linear: All the straight cuts in one direction are made in order to save time and is recommended for machines fitted with vacuum tables or where the board is securely clamped. See fig.37
‘L’ Mode: The external cuts are made as an L shape; this mode is faster than Around mode and is largely designed for machines not fitted with a vacuum table but that have a fold away clamping system.
The next 3 illustrations in the help file show the difference in the help file
You will have to go into the setting and re-calubrate the LT mode
I use the around Mode,
poliopete
Nice one Steve
Succinct and practical advice as is the norm from you
wouldn't expect any thing less. Although I don't have a clue as to what you are talking about I'm sure Paul will find it invaluable, just wish I had a cmc
I for one hope you will continue posting on the excellent forum after you retire. When is that by the way? how many months, days, hours, mins
Peter.
Peter.
