Dutch Ripple and other stuff
Timh
Re: Dutch Ripple and other stuff
Post by Timh »
thanks for that
I made them on the spindle moulder out of obeche so I can alter the sight edge profile to do a few different shapes
I will post more pictures after they have been finished
If I was to hazard a guess, I'd say the spandrels were cut from flat obeche with a bevel and in-cut element added and then mitred.
Otherwise you couldn't get the sharp corners if you did it all in one piece. Good thinking. :clap:
** As you have just said and I didn't read. :lol:
Yes, I can see how that makes good sense.
Timh
Post by Timh »
Thanks Fellas
the obeche is 38mm thick and planed down to 30mm
then profiled the sight edge on the spindle free hand first and then fed through on a feed wheel after to do the straight edges and create the sharper edge where the scoop part meets the straight part
Then added a rebate
mitred and pinned as normal after
I have gessoed them this morning
Very nice! Out of interest how big is the whole frame? I think that it could look amazing if it was a substantial size.
Timh
Post by Timh »
the rebate is about 16 x 11 inches with an outside size of 24 x 19 - both approx
could be made bigger but like the small and mighty look
