Removing grease stains from mountboard
Share your CMC experiences.
Or seek help and advice
Postby Mary Lever » Mon Aug 08, 2016 1:03 pm
I have a small grease/oil stain on a mount. I was told I could remove it using an iron, brown paper and lime juice. Does anyone know how much and how one should apply the lime juice? Or does anyone have an effective way of removing an oil/grease spot? Thanks,
Mary Lever
EstLite Frame Pricing Software
Re: Removing grease stains from mountboard
Postby Jamesnkr » Mon Aug 08, 2016 1:14 pm
Putting brown paper over the stain and then using an iron on it may work.
Lime juice, though is a 'traditional' invisible ink, developed by heating it. Surely the lime juice will leave you with a brown splodge instead?
Time to experiment, I'd have thought...
Jamesnkr
Organisation: London UK
Interests: framing
Postby featurepiece » Mon Aug 08, 2016 2:24 pm
Have you tried a few applications of lighter fluid?
featurepiece
Postby Roboframer » Mon Aug 08, 2016 3:11 pm
Unless it can be removed quickly and/or unless the mount has a fillet, deep bevel/whatever attached or is hand decorated, I'd toss it and cut another one, but in those cases I have had success with clean water, brushed with a progressively dry brush and also with extra fine (like 240 grit) paper - as long as it's an off white board, in fact the water method, or any liquid method can be bad on coloured boards, can leave a tidemark.
Back behind the velvet rope, Ladies.
Organisation: Angmering Framing & Stitches
Interests: Cooking, drawing.
Postby Graysalchemy » Mon Aug 08, 2016 3:47 pm
I would bin it and start again it's not worth the time and effort compared to the cost of a sheet of Mount board.
Organisation: AIL
Interests: Picture framing and brewing
Postby Roboframer » Mon Aug 08, 2016 3:51 pm
Yeahbutnobut, what if it's washlined and edged with real gold leaf!
Postby Graysalchemy » Mon Aug 08, 2016 3:58 pm
Well if that was the case I would have priced in for wastage anyway so it woukd be no different to a standard xheet. I think if you start trying to bodge in imperfection or error you are doing your customer a disservice, they are not paying for mistakes or imperfections.
Organisation: AIL
Postby Roboframer » Mon Aug 08, 2016 6:49 pm
Material wastage is factored in anyway - but not really on something that is priced pretty much on time alone and I'd be looking at complete and fast removal with no trace or toss it anyway - not a bodge.
Even the simple plain mount is worth a quick go at before writing it off.
Return to Discussion
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
