Questions..
Share your CMC experiences.
Or seek help and advice
Questions..
Postby Gary » Wed Apr 15, 2009 1:54 am
Hi, im Gary from singapore,
Im not a framer but an empolyee of my company.. My boss is though.. he's CPF from PPFA..
Im currently using an old model of the valiani CMC Mat pro 120..
i have a question regarding it,
Do u guys place anything on the blueish base of the machine? that's because everytime i do a cut design, the blade will hit the base, & i would get "scars on the base" so to counter the problem i had, i have to use a 8ply mat board to prevent the scarring... i would like to know is there any cheaper/better solution for this matter? 8ply matboard is really expensive in sg..
http://www.qframing.com.sg/
Im not a framer but a visualization Artist...
Gary
Organisation: Qframing Pte Ltd
Interests: 3D modeling/rendering
Loft
Re: Questions..
Postby Merlin » Wed Apr 15, 2009 9:29 am
Hi Gary
We used to have the older version of the MatPro 120 before upgrading.
We had the same problem and always used 2 (two) sheets of cheap 1400 micron mountboard as slip sheets.
Hope this helps
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Re: Questions..
Postby Jonny2morsos » Wed Apr 15, 2009 10:09 pm
Hi Gary
We do the same as Merlin and use two sheets of mountboard which we buy as seconds i.e. imperfect from a wholesaler. These cost us GB£1.25 each and less if we buy a quantity. Make sure you use two though as it prevents cutting into the base when you forget to adjust your blade after cutting through two sheets.
I an sure if you ask a supplier for some rejects they will find you some.
John.
Jonny2morsos
Re: Questions..
Postby Dermot » Wed Apr 15, 2009 10:43 pm
My supplier gave me 21 damaged sheets free gratis today…some are quite a mess with marks and footprints but they will be fine for under sheets…….they were going to dump them in the skip…. :D
I have the stainless steel under sheet which means I will only have to use one sheet of mount/mat board as a under sheet.
Dermot
http://www.ote.ie Preserving History for Tomorrow
The future has a way of arriving unannounced.
Dermot
Organisation: On The Edge Ltd.
Interests: Preserving History for Tomorrow | Archival, Conservation & Preservation
Re: Questions..
Postby Gary » Thu Apr 16, 2009 8:34 am
ok, thanks for your kind answers...
i have another question, let's say my boss uses crescent rag-mat boards (cotton based).. i always encountered burred/jagged edges when i cut out the frame window..
how to prevent that from happening, even when i change into a new blade?
Gary
Re: Questions..
Postby Merlin » Thu Apr 16, 2009 10:46 am
Gary wrote:i have another question, let's say my boss uses crescent rag-mat boards (cotton based).. i always encountered burred/jagged edges when i cut out the frame window..
Does this happen when cutting out standard Rectangle/Square apertures or when you try to cut some of your designs.
Merlin
Interests: Aviation
Re: Questions..
Postby Gary » Tue Apr 28, 2009 1:26 am
standard valani squares/rectangles.. does the softness of ragmats have to do with the jag-ness when cutting?
Gary
Return to Discussion
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
