PLT file guidance
Upload/download patterns, templates, designs.
PLT file guidance
Postby MikeSwannick » Tue Feb 16, 2016 6:49 pm
Kind any kind sole give my PLT file the once over please. I've attached a jpg of what I expect it to look like but need to know if the file meets the standard for cutting by a CMC and whether a CMC will produce what I'm expecting. I was going to fill in the areas I expect to cut out but decided against it.
It's a mount with a standard aperture with logo in the bottom left hand corner which should have bits cut out of it.
PLT file:
BB logo mount.plt
Be gentle, it's my first one :sweating:
Mike.
MikeSwannick
Organisation: Game of Frames
Interests: All things zombie. I also do data recovery.
EstLite Frame Pricing Software
Re: PLT file guidance
Postby GUNNAR » Tue Feb 16, 2016 11:39 pm
Hi Mike
It will depend on the overall size you will want it to cut out. The gap between the collar and the back of the neck seems rather narrow and may not leave any visible face paper. Try adding a contour of between 1.2 and 1.4mm to the design depending at what angle the bevel is cut at. This will give you the visual of what it will look like cut with a bevel. It can completely change the look.
Sarah/GUNNAR
GUNNAR
Postby MikeSwannick » Wed Feb 17, 2016 7:29 am
Hello Sarah,
Thanks for the comment, I'll do as you suggest. Just to confirm, the bevel in the Coreldraw file is to simulate the finished product but the .PLT file is hairline sized lines to indicate a cut?
The design is (should be) 33cm x 26.6cm.
Mike.
MikeSwannick
Postby GUNNAR » Wed Feb 17, 2016 8:01 am
Hi Mike
Yes. A broader line or a contour in Corel will help you replicate the visual of the bevel in Corel.
Sarah
GUNNAR
Postby Steve N » Fri Feb 19, 2016 2:52 pm
Just had a look at your file, and I agree with Sarah about the gap/spaces, majority of them are less than 3mm, some look like only 1mm !, so once you have cut the windows you are not going to have any card left, also, quite a few of your shapes are open, not welded together, ie as this image I pulled it apart, I don't know what CMC you are using but you might find that you will be bevel different on each section of the shape,such as normal on the right hand side and reverse on the left hand side (or vice versa)
I would do a continuous path all the way round each shape, don't do it in sections, because you have to then join the sections
Sorry got customers just come in
"Just because you seen it on the internet, does not make it true or right" -Abraham Lincoln
Postby GUNNAR » Fri Feb 19, 2016 3:36 pm
I also had a look at this earlier in the week and my findings were exactly the same as Steve N.
Regards
Sarah/GUNNAR
GUNNAR
Postby MikeSwannick » Fri Feb 19, 2016 8:28 pm
I've changed the design taking into account the gap size, so in the future anything in a design approaching the 3mm gap should be carefully considered.
The gap between the lines I'm surprised at. In Corel, I used 2 point, Bezier, 3 point and another line option when doing the tracing. After zooming in specifically to close up the gaps I thought I'd got it covered. I suspect I haven't correctly 'joined' lines of different line types and I guess doing each shape all in one hit would overcome that? Back to the tutorials then.... :?
Thanks for the input.
Mike.
MikeSwannick
Postby Steve N » Sat Feb 20, 2016 6:50 am
You will have to make the gaps far bigger than 3mm as at that size you could fine the mountcard de-laminating , we normally have a minimum gap around 7-8mm. on some our work anything smaller would weaken some parts of the designs we are producing
Don't forget the machine is calibrated for the bottom of the bevel , the bit at the back of the mount nearer to the art work, so the size of the gap could be different on different thickness of mount card
Plus nice sharp blades will also help
Return to Designs
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
