Wizard-CMC Slope Box Template
Upload/download patterns, templates, designs.
Postby kev@frames » Wed May 26, 2010 8:59 pm
a cove mat template file for Wizard Mat Designer. This will only cut in a licensed version of Mat Designer.
You can use this standalone, tinkering with the values: or enter the readings generated with John's Slope Sided Box Design Utility.
Quick how to
First set the matboard size.
Materials size in slope box designer = Matboard size in WMD
S in slope box designer = Reveals value in Layer 1 and Height value in Layer 2/Parameters in WMD (set both the same value)
C in box designer = width value in Layer 2/Parameters in WMD
X and Y in box designer = Width/height values in Dimensions in WMD
These values will replicate the design generated in slope sided box designer. (You do not need to save any PLT files)
CUTTING:
Cut from the back
Cut layer1 as a score-line by setting blade to a bit less than your usual v-groove setting. Cut Layer 2 as a full depth cut.
experiment with reverse bevels depending on your box angles.
kev@frames
Interests: 4 or 5 ...
Lion Pictureframing Sipplies
Return to Designs
cron
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
