map
Ask for and give assistance
map
Postby Ed209 » Tue Nov 14, 2017 6:13 pm
Just been asked about the following please advise on best method please, Apparently the map is paper so no built in rigidity.
Have already done a couple of jobs for the customer and more to come so really don't want to decline this one if possible.
Hi. I have a map of the world that I'd like framed for my husband for Christmas. It needs to have no glass as it's a scratch off map used to scratch off places you've visited (scratch card style). How much would it be for a black frame 76cmx48cm Please
Ed209
Mainline Strathdon
Re: map
Postby Glimpse » Tue Nov 14, 2017 6:43 pm
I get loads of these! I mount on a sticky board and drop it straight in the frame.
Dead easy and a good earner - no mount, no glass and no flumbs ! And you can charge a bit for mounting.
Glimpse
Organisation: Longridge Art & Framing
Interests: Art, Photography, Photographic Restoration, Digital Art, Cycling.
Re: map
Postby Tudor Rose » Tue Nov 14, 2017 9:38 pm
We took another one of these in for framing this morning. We put them through the Jetmounter to stick them down to board, then straight in a frame. They are pretty straightforward to do.
Proud to be serving as Members' Warden of The Fine Art Trade Guild http://www.fineart.co.uk
Member of the Guild and the PPFA
Tudor Rose
Organisation: The Framing Lot
Re: map
Postby Ed209 » Tue Nov 14, 2017 9:45 pm
could I do this without a Jet mounter or is it to big to get satisfactory results with just a self adhesive backboard and roller? As I have read quit a bit about people not being happy to do anything by hand over the size of a A3 photo etc.
Ed209
Re: map
Postby Ed209 » Tue Nov 14, 2017 9:48 pm
while were on the subject if you had to get a Hotpress or Jet mounter which in your opinions is the most practical for general use
Ed209
Re: map
Postby Tudor Rose » Tue Nov 14, 2017 10:09 pm
We did these with a hand roller before we got the Jetmounter. We tended to go for belt and braces approach of doing it by hand/roller and then leaving it under a load of backing board (lots of weight) overnight to be doubly sure. They usually come with a tissue/film over the top of the map, so use that over the surface when you are putting pressure on it to avoid any marks etc.
As for which is better - Hotpress or Jetmounter - well we are lucky enough to have both. We got the Hotpress very early on on a Spring Fair special offer through D&J Simons because we picked up a customer at the time (now retired) who then pretty much paid for it with the work we did for him, and we managed fine with that for a long time. We got the Jetmounter second hand through this forum from someone who was retiring. These days it tends to be the thing we use most. If I had to keep one of them it would be the Jetmounter. We even used it to help bond down the sticky back material to our chevron boards! Having said that it really does depend on what your prime use for it would be and what your business set up is. We don't do any printing or anything.
One thing I would recommend though is the courses they run to help you get the most out of your purchase.
Tudor Rose
Re: map
Postby Steve N » Wed Nov 15, 2017 10:08 am
have a look at the youtube vid in the other thread , the next post down from you comment
https://www.theframersforum.com/viewtop ... 32&t=15953
"Just because you seen it on the internet, does not make it true or right" -Abraham Lincoln
Interests: photography,travel, wildlife, walking,art, falling asleep on sofa in front of the telly
Re: map
Postby Glimpse » Wed Nov 15, 2017 10:29 am
Ed, don’t worry about the size, they’re fine for sticky boards. Just watch that vid Steve linked to.
The maps are printed on decent paper, around 200gsm, and have a laminate on the face, so you’d really have to work hard to get a wrinkle in it! The lam makes air pockets tricky to disperse if they occur, just make a tiny prick with the point of a scalpel (in an unobtrusive area like a black printed line) and tease the air out.
I’ve gone down the hot press only route, simply due to the sheer versatility. There’s not much I’d ever need a jetmounter for that can’t be sorted with sticky boards and a hand roller.
Glimpse
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
