Large mount cut
pramsay13
Large mount cut
Post by pramsay13 »
I'm needing 2 large mounts cut, approx 1.5m x 1.5m with a 150mm border.
Can anyone help?
Re: Large mount cut
Think that's a bit beyond the pale. :? I don't know of a source of board that size. Not in one piece anyway.
Even making one from flat wood with mitred corners would be a challenge.
What's the nature of the item to be framed?
iantheframer
Interests: photography
Re: Large mount cut
Post by iantheframer »
Ian
pramsay13
Re: Large mount cut
Post by pramsay13 »
Thanks Ian, I'll see if they can do other sizes.
I've got a quote from John Jones, they can do them that size
iantheframer
Re: Large mount cut
JPP are a supplier only, useful to know of for boards and papers, but they do not cut mounts
Ian
pramsay13
Re: Large mount cut
Post by pramsay13 »
Just checked that quote from JJ, and it's over £300 for one mount that size (not including delivery) :shock:
I think they misread my request for a white mount and have quoted for it in solid gold.
Re: Large mount cut
Post by Graysalchemy »
That would be about right for John Johns. :giggle:
Framemaker Richard
Organisation: framemaker
Interests: Antique frames
Re: Large mount cut
Post by Framemaker Richard »
Did you find anyone else who can do it?
You could get the mountboard from John Purcell Paper and cut it by hand. I have cut oversize mounts with a Keencut straight edge and hand held cutter with no problems, they looked like they were done on a mountcutter, although it was 1500 micron and not 2200... which I would not be so keen on cutting.
I wonder how much the 162cm x 218cm board costs? its got to be around £90 a sheet. Mark-up, add some labour, and £300 is not crazy expensive if you ask me. It's not as if you can get it done at your local framer :D
Re: Large mount cut
Yeah. Too big for any manual cutter or a CMC (unless someone knows different in which case I will stand corrected).
Cutting with a straightedge/handheld cutter while simple enough is fraught with peril. Sooner or later you are going to knacker a £90 sheet (or two...) so that price for the finished article isn't quite as exorbitant as it might seem.
As my old gaffer used to say: "Things always look easy when someone else is doing them". :P
Re: Large mount cut
I think you would find one of the large CMC cutters that sign makers use would cut it. :giggle: :giggle:
markw
Re: Large mount cut
Post by markw »
Valiani CMCs with Vstudio software can cut oversize mounts - in several pieces that are then joined. Ive never used the function but it looks pratical. The join is bevelled to create as clean a join as possible - would cost less than £300.
markw
Re: Large mount cut
Post by markw »
Valiani cmc would cut the large mount as four pieces.
image attached
screen grab of Vstudio layout
IFGL
Re: Large mount cut
Post by IFGL »
I have used that feature a few times, it works fine especially with textured mount card.
