Chinese pictures to frame
- Organisation: FrameCraft
- Interests: Picture Framing.
Hi guys another one I need your Knowledge on! I've got 11 of these Chinese pictures to frame. My customer wants them surface mounted as opposed to a window mount as he says it looks more traditional. So I thought of float mounting them however the paper is see through so any hinging or other method would be visible. Any ideas, suggestions welcome please! Than you, Dave J.
- 16710462_10154193388366921_2050665972_o.jpg (37.98 KiB) Viewed 13928 times
Re: Chinese pictures to frame
Traditional?
To my way of looking there is little merit in float mounting them. Technically, it would be problematic.
Are they valuable?
You could dry mount them to a thicker piece of paper, then you could float them.
You could dry mount them onto a coloured background.
Wouldn't recommend the last two options.
The best way would be to use a window mount, then you could employ edge mounting with Mylar strips so
no gluey attachment at all. Or two tiny hinges. Easier.
As far as the customer's wishes are concerned, you are the framer not he. Sometimes people get ideas that seem
reasonable to them but have no idea of the (im)practicalities.
Are they valuable?
- Organisation: SGF
- Interests: Music Music Music
Not sure why your hinges would show through, if your undermount is the same colour as your hinging tape. They will obviously show up against MDF ( like in your picture), but you wouldn't be hinging them onto that!
- IFGL
I successfully mounted some velum title deeds using Roboframers method in this thread, they are fairly see through and there was no indication of where I had mounted them when viewing the finished Item, I am glad I used that method actually because I had forgotten to copy what was on the back for the customer, I was able to remove all traces, copy it then reframe
http://www.theframersforum.com/viewtopi ... lum#p75298
I would still recommend window mounting it though.
Thanks guys, no not valuable. The MDF is only there because I flatten big old posters between it, tissue paper, mount card sheets then MDF on top, you'll be pleased to know! Yes window mounting would be sooo much easier. Perhaps I'll knock one up and show him how great it looks!!
I'm not even gonna tell you what he settled for in the end, completely adamant! I'm gonna be cringing when I do these but hey, the customer is always right...right!!
a couple of posts up I know, but where is Rroboframer, and Grays for that matter
- StevenG
DaveJ wrote:I'm not even gonna tell you what he settled for in the end, completely adamant! I'm gonna be cringing when I do these but hey, the customer is always right...right!!
Now I want to know!!!
Well he wanted a very slim brown frame, I found a gorgeous deep bevelled Nielson moulding in brown with a natural grain finish and showed him how they could be float mounted to the cream mount board (yes maguirei you were right the hinges wouldn't show) I explained that the fillets would match the mount card or even a small spacer but no he wants them flat against the glass! I asked if they were expensive and he said yes they were, sent from china and are presents for friends. I tried, I explained but he's adamant it will 'look better'. Its not a price issue either, genuinely wants it to look like that, Oh well.... I told him I'm not responsible regarding the conservation issue!
He said window mounts look horrible, I've done 5 for him before with window mounts! Cheers mate!
He's a lovely fella but just wasn't concerned about the contact with the glass and the flat look, Oh well, like I said the customer is always right, maybe they'll look good!
- David McCormack
- Organisation: Framing
Naughty step see this post http://theframersforum.com/viewtopic.ph ... 20#p117720Trinity wrote:a couple of posts up I know, but where is Rroboframer, and Grays for that matter
I had a similar situation a week or two back. Guy with some oriental calligraphy that is wife (who wasn't oriental) had done.
Just about every thing he wanted was very bad. He wanted them stuck down. With spray glue. He had a previously stuck one
to demonstrate. It was peeling off. No problem about them touching the glass though, he didn't want glass.
I'm sure some people think the only reason framers use mounts is to sell a bigger frame. Sometimes you have to dig in your heels
and tell people what's what.
Well I did say that this wasn't with conservation in mind and he said it doesn't matter. After all it's his pictures and his choice. On the upside I have the moulding and the mount board in stock that he wants and at the end of the day am here to make a living so bobs yer uncle!
As a general rule, in a centrally-heated house, up-against-the-glass is absolutely fine. It's not best practice, it's not conservation. But lots of pictures live like that for years without any problem.
Interesting thanks, glad it's not a complete no no.
Yep. I'll happily explain to customers why I think they should do them a certain way but I'm not going to faff about with clever conservation methods if the customer just wants it glued down. As you say, got to make a living.DaveJ wrote:Well I did say that this wasn't with conservation in mind and he said it doesn't matter. After all it's his pictures and his choice. On the upside I have the moulding and the mount board in stock that he wants and at the end of the day am here to make a living so bobs yer uncle!
I've seen a frame with notes scribbled on the inside saying that this is what the customer wanted even though they were advised otherwise.
Yes agreed, Ha! Note, love it!
Jamesnkr wrote:As a general rule, in a centrally-heated house, up-against-the-glass is absolutely fine. It's not best practice, it's not conservation. But lots of pictures live like that for years without any problem.
That's absolutely true. I've seen lots of up-against-glass pictures that were OK. I've also seen a lot that weren't.
I've had photos that looked fine but on removal were stuck to the glass and got damaged/torn.
Usually on account of acidic backboard - or being framed with nothing between the picture and the wood backboard. Or condensation on account of being kept in a damp garage.prospero wrote: I've also seen a lot that weren't.
.... but more often the glass.
People often have the impression that placing glass on a piece of paper will keep it flat.
They can be forgiven for thinking this, but in actuality it's a surefire way of making it go wavy.
That's apart from the ink-sticking issue.
