Hello all,
Can anyone name this moulding? I have been asked to match it and can't find anything remotely close in either Wessex, Simons or Lion. It looks like obeche with a pewter slip. I can understand why the client isn't keen to use the same person for the second job!
Thanks for your help,
Charles
Name that Frame (Moulding)
- Organisation: Blunty's Mill B&B
- Interests: Sport, signature collection, looking to start framing.
- IMG_0136.JPG (1.67 MiB) Viewed 1726 times
- Organisation: Ramaria
- Interests: Photography
Re: Name that Frame (Moulding)
I can't tell what the size is from the picture you provided, but it looks a lot like the 74mm 'Langham Mono' from Lion. (code is L2211)
Check out the 'Langham Mono' range: https://www.lionpic.co.uk/r/25114/Langham-Mono
Unless your customer is absolutely keen on that particular moulding, this should do just fine as a replacement and is of a much higher quality.
Maybe the framer has a label on the back and you can ring them?!
