Jumbo Conservation Mountboard
Framie
Organisation: Anything Framed
Interests: Custom Framing, Hand Finishes and Multi Aperture Mounts.
Post by Framie »
Hi, I have some very large prints to frame (print size1096x1375mm + border) and I'm looking for Jumbo Conservation Mountboards but ideal with a grey face paper, can anybody recommend anything, please?
Anything Framed
louisesimon
Organisation: Peckham Pictures (closed)
Interests: Framing, Art, Photography
Re: Jumbo Conservation Mountboard
Post by louisesimon »
Concidentally first job on my to do list is try and find a jumbo grey board...spent a while looking on Friday buy couldn't find anything.
Framie
Post by Framie »
Yes, I've had a good look about but can't find anything.
Anything Framed
Framemaker Richard
Organisation: framemaker
Interests: Antique frames
Post by Framemaker Richard »
Crescent do a very dark grey (Newcastle 81123) and a very light one (Inverness 81121) in 40" x 60" (1020x1520mm) jumbo size museum board, but not sure if wessex hold stock of them.
These are still not big enough for your print size 1096x1375 excluding border... Crescent also do a 1220x1830 and 1220x2440 but only in white...
Can you cut it once you get it? :roll:
One way of making big mounts without faffing about with big sheets is to use a plain wood profile
and mitre it. Rose&Hollis do a 70mm flat with a bevel. It's good and thick - about 8mm.
You do have to paint it though but at least you have an infinite choice of colours. :D
Framemaker Richard
That's a wise point from Prospero! forget to say about that :Slap:
super big mounts I do with a hand cutter (logan I think) and a keencut 72" straight edge.
Splicing boards together is a good solution if no other is available, as you can use standard size boards in all the colours
Jamesnkr
Post by Jamesnkr »
Or use fabric stretched over mount board. Always looks good.
Framie
Post by Framie »
Thank you Richard, white is the last colour wanted but the Crescent size is perfect just shame about the lack of colours.
Even more fun, its a double mount :giggle:
Prospero I was thinking about doing that, the only problem is sometimes on painted stuff when it's touching the coated glasses I get funny little marks. Might just the paint I use or not letting it cure enough.
I've never done fabric stretched over mount board, what does that look like squashed against the glass?
I did think about wrapping a slip, mitre and join.
Anything Framed
Jamesnkr
Post by Jamesnkr »
Framie wrote:what does that look like squashed against the glass?
Like fabric behind a piece of glass?! If you don't believe me, press a beer glass up against your shirt! Anyway, it looks fine.
louisesimon
Luckily my job is float mounted, annoyingly it's two panels with a gap in the middle, so the full splice will be on show, tempted to try the fabric, think that will look really good.
Yes you are absitively right. But I have a cunning plan....
When do them I run a thin strip of linen tape around the outside of the 'mount' - no wider than the rebate lip.
This lifts the glass off a smidge and no optical artefacts. Sometimes I use some 2-ply board with ds tape the same
way when more lift is needed.
Framie
Post by Framie »
That sounds like a good idea, thank you.
Anything Framed
Framemaker Richard
Like Prospero, for painted slips that come into contact with glass, I use strips of board or barrier card and double sided tape to raise the glass away from the paint surface.
