Polecore 2 part glue..
Ask for and give assistance
Postby Mark-ND framing » Mon Jul 10, 2017 11:11 am
Morning all, I have just produced a job using black 38mm Polcore from Wessex. First time I have used synthetic moulding. It cut really well and looked as if the assembly would be easy. I bought the 2 part glue and used it before underpinning. I seems to be a good fix at first but was really brittle when any pressure was applied and easily opened. Anybody have any views/experience in using this glue?
Thanks,
Mark.
Mark-ND framing
Organisation: Naughty Dog Creative Framing
Interests: Picture Framing. Photography. Graphics
Loft
Re: Polecore 2 part glue..
Postby tebbles » Mon Jul 10, 2017 6:31 pm
I haven't used that, but mainline have an excellent glue for use with polcore.
http://www.mainlinemouldings.com/index. ... D=I00-0300
tebbles
Organisation: the frame shop
Interests: music, framing
Postby Mark-ND framing » Mon Jul 10, 2017 7:23 pm
Thanks for the advice, I will try that.
Mark.
Mark-ND framing
Postby featurepiece » Mon Jul 10, 2017 9:06 pm
I don't know what the 2 part glue you're using.
I only use the stuff from mainline, cut the moulding & then use a bit of the glue (too much I've found can be counterproductive), hold the mitred ends firmly until it's solid, I then pin them once the glued joints are good.
Does that make any sense :? :)
featurepiece
Postby Mark-ND framing » Mon Jul 10, 2017 9:39 pm
Absolutley, it makes perfect sense thanks. I was using a cyano activator and superglue but it seemd to eat into the moulding and then fall apart....I will try your technique and see how that goes. I did like the finish though..
Thanks again,
Mark.
Mark-ND framing
Postby John Ranes II, CPF, GCF » Mon Jul 10, 2017 10:39 pm
I know that plastic moulding has been around for a long time now....
- It looks fantastic these days with some great finishes!
- From 5 feet or 5 inches away, can you really tell the difference!
But in truth it is still plastic... In 39 years, we have never brought in any outside of customers bringing in frames for repair or reuse... Sorry, but I don't like plastic.
(I'm also a REAL Ale drinker... and don't touch that American C*** Budweiser and Miller!) :Slap:
Cheers,
John
430 E Northland Ave
Appleton, WI 54911-2127 USA
Member: FATG & PPFA
The Frame Workshop
Organisation: The Frame Workshop of Appleton, Inc.
Interests: Philately, Darts, Beer Making, Photography, Golf
Postby Mark-ND framing » Tue Jul 11, 2017 12:17 pm
:lol: :lol: :lol: Brilliant, I have to say it's wood for me but you know them there pesky customers!! Enjoy your 'old ferrets tackle" :lol: :lol: :lol:
Mark-ND framing
Postby technoframer » Wed Jul 12, 2017 11:05 am
With Polcore I have found the best glue is a branded High Viscosity (thick) industrial Superglue.
HV is is much better than lower viscosity because...
It has a longer curing time, typically 30 seconds which gives time for alignment of mitres.
It bridges the 'grain' gaps of polcore perfectly.
It doesn't run off the face of the mitre after application, which keeps tools and fingers glue-free.
Activator not necessary.
Joining plastic mouldings is like any skill, it takes time and practice to get a perfect join. Joints should be stronger than the moulding itself with wedges only needed for a temporary hold. Correctly joined you should not be able seperate a mitre, the moulding should break first.
Not used wood for years now. :D
technoframer
Organisation: Yorkshire
Interests: Picture Framing, Eating and Sleeping. Sometimes at the same time.
Postby Mark-ND framing » Wed Jul 12, 2017 12:01 pm
Thanks for the advice technoframer...(great name btw) I will have a go at this. I agree though I was surprised by the look and feel of the finished frame!! My client always specifies it as it sells well!!
:D
Mark-ND framing
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
