Prop-up aluminium frame
- Beau
- Organisation: Belvoir Gallery
- Interests: picture framing, astronomy
Apart from using the two part strut back hinges does any producer of aluminium frames do a neat gadget to make their frames prop?
Re: Prop-up aluminium frame
what size frames, as Arqadia range of Barth Ready Made Aluminium frames A4's have stands
or could use lion's
https://www.lionpic.co.uk/p/32046/KS-2- ... -Black-100
with
https://www.lionpic.co.uk/p/28634/Squar ... 00pc------
or could use lion's
with
- Beau
Thanks Steve -- Yes we do use those slip-on brackets like you mention but recently I was using Nielsons profile 269 and there was not enough rebate for the slip-on bracket to fit in the rebate. I messed about glueing bits of card to the backboard. But I have just this second realised what i could have done instead. I should have used two backboards, one being shorter to lift the slip-on bracket higher than the aluminium (yet another senior moment). Thanks for your reply.
