MatPro CMC problem
- Organisation: Prairie House Custom Frames
- Interests: I own a small Frame Shop in Springfield IL and at times would like to exchange Ideas ask and give advic to other picture framers around the globe.
MatPro CMC problem
Hoping to get some advise from someone familiar with this machine. I just tried cutting an 8ply mat using the "single shape with outside cut" feature. Each cut the machine would cut the correct lenth lift up the blade travel an additional .5" pivot and continue. This would in addition to not completing my corners would add .5" to each the X and Y dimensions Can anyone tell me what could cause his? Ive used this feature before with out a problem. Thanks in advance
- Merlin
- Organisation: Merlin Mounts
- Interests: Aviation
Re: MatPro CMC problem
Not enough information given to give an answer.
What software are you using. What head are you using. What thickness mountboard are you using.
Has this just appeared
Check the FB Valiani Mat Pro CMC pages
https://www.facebook.com/groups/121377208461439/
John GCF
The Software is Future mat designer. The mat board is an 8ply rag. the head I dont know , I bought the machine used, its a CMC 150.
Will this help?
- 20171017_193913_37732602162_o.jpg (5.73 MiB) Viewed 4179 times
- 20171017_193902_37732588602_o.jpg (3.89 MiB) Viewed 4179 times
screen shot
