Mounting a map
Posted: Mon 16 Apr, 2018 10:40 am
by Yacht762
I’m trying to mount a large map which my customer wants to use as a pin board showing where he has been, I’m using ‘Sundaela’ board, popular for notice boards but am having difficulty mounting the map. It has a glossy finish, I’ve tried spray mount, then spray carpet adhesive both without success, we’ve had to buy another map as a result. Any ideas how best to mount it please.
Re: Mounting a map
Posted: Mon 16 Apr, 2018 11:45 am
by David McCormack
Would it work mounted to self adhesive foamboard? If you don't have a roller-press to apply even pressure on the foamboard then it can be done by hand with a
brayer rubber roller. Mount it to standard self adhesive board first, like Arqadia fast-mount, and you can apply a fair amount of pressure with a hand roller and then glue the mounted map and board to foam-board with wet glue.
Re: Mounting a map
Posted: Mon 16 Apr, 2018 12:42 pm
Welcome to the Forum Yacht762.
Hope you don't mind me moving this topic to the help section....
Re: Mounting a map
Posted: Mon 16 Apr, 2018 1:39 pm
by theframer
Good advice from David thats the way to do it
Re: Mounting a map
Posted: Mon 16 Apr, 2018 5:11 pm
by StevenG
foamboard would be my choice too, actually I done one about 2 weeks ago. I wasn't sure that the pins would stay in but they held without issue
