World Cup tickets.
- Organisation: DIY
- Interests: Cycling, golf, art
World Cup tickets.
I’ve been asked to frame to some World Cup tickets, program & pass badge. The customer has asked for a floating window mount, which is good.. The program is fairly heavy and the customer mentioned the possibility of reversibility in the future. It didn’t seem to be a deal breaker, but just looking for some thoughts/suggestions..
Re: World Cup tickets.
I have framed world cup tickets and passes before. We have a leading member of a local club, who bring in sizable quantities of football memorabilia on a regular basis and you name it, I've framed it, or at least mounted it for him. Items like this, I like to encapsulate between two layers of Mylar, so that there is no fixings whatsoever on the tickets, or the passes and mount them behind an oversized window mount, with a contrasting colour of mountboard behind.
A second mount in front of the oversized window mounts with aperatures for each item can have just one aperture to tie all the items in the rear mount together as a set. If necessary the front mount can be a double, or even triple mount to introduce coloured reveals as appropriate.
- David McCormack
- Organisation: Framing
I would consider using melinex/mylar (clear polyester film) in some way, possibly straps. Have a read through the attached pdf for some ideas.
Lion sells the film.
The clear film encapsulation technique in the PDF file on page 4 is the technique I am talking about. It's not only less noticable than straps, provides an all round conservation envelope around each item. I view this as the ultimate long term protection for these items and of course it is fully reversible at any time in the future. Also it's a real easy thing to do. After you've done a few of these, you will find it so easy to do, that it will become your prefered technique for items like this.
- David McCormack
Out of interest Mark which brand of double sided tape do you use for double encapsulation? The 3M 889 tape mentioned by Jim Miller doesn't seem to be available anymore. Cheers.
- Organisation: DIY
Thanks guys, really appreciate the advice.
No I could not get it either, so I use a different 3M's tape available from Lion and described by lion as suitable for the same use. I find that it does the job just fine.David McCormack wrote:The 3M 889 tape mentioned by Jim Miller doesn't seem to be available anymore. Cheers.
