Framing outdoor business signs
- Organisation: Whitby Picture Framing
- Interests: Walking when my back allows me, photography, travel, cars, gaming on the PC
Hi, I've been asked to do some frames to go around some outdoor signs for a local business. Other than making them up from timber, I've been wondering about using Polcore instead. Does anyone know how weather resilient they are? They will be facing North so bleaching won't be a major concern, be we do live on the North East coast which gets a battering in the winter. Any advice is appreciated.
Re: Framing outdoor business signs
I have some offcuts of Polecore that have been outside for well over a year and used some the other day and it made up a frame as good as new.
I suppose one problem could be sagging if long lengths but you could silicone on to sign.
Polcore is made of polystyrene and does not take kindly to repeatedly cycling through extremes of hot and cold, or extreme changes in humidity. Having said that there can be problems with wooden frames as well, so there's a lot to think about.
If the polcore is going to be suject to temperature differences between one side of the moulding compared to the other, one side will want to expand, while the other side will want to contract, or not expand as much. The resulting stresses will create forces that tend to bowing the moulding and if the frame has anything restraining the frame from bowing then this may produce crazing of the finish on the moulding, because the stresses cannot be relieved by the moulding bowing.
The same will apply to wood mouldings to some degree if moisture gets into one side and not the other. You can get a certain level of protection by sealing the wood with yacht varnish, but even yacht varnish does not last forever. Added to this most underpinning wedges will rust away to nothing over extended periods in a damp environment, so you do need to take a lot of things into account for jobs like this.
Have you considered aluminium frames, they are not necessarily the answer in every situation, (you may not get the dimensions, finish, or style that you want), but they will stand up to the elements extremely well. Probably not what you wanted to hear, but I'm telling you what can happen in particular situations, but that does not mean that you might not get away with in the particular situation that applies with this job. I just don't know.
- Interests: Pubs
I know of a framer who has had Polcore chevron samples stuck on his outside sign for 7 years and they still look good. He used the range below but he reckons Polcore is ok outside so long as you avoid metallic foils.
https://mainlinemouldings.com/index.php ... goryID=795
Twitter #MainlinePolcore
My sign is marine ply edged with Simon's M99b - stained and given about 10 coats of Yacht Varnish. I took my time building up
the varnish (back and front) and so far has been hanging on a west-facing wall for over 24 years. It's a bit weathered now, but you can still read it.
The M99b is RAMIN. I doubt if Obeche would last more than 3 years if that. I would use oak if I had to do the same today.
Thanks for the feedback everyone, more food for thought.
Many years ago I made a notice board for the village (our village later became a town) I definitely recall using "Parana Pine" and like prospero, copious coats of Yacht Varnish
It generated a great deal of business because of goodwill I assume so I kept my eye on it. It was in situ for two years and before it was nicked never to be seen again
BTW Thanks for posting Ricky, it's appreciated when suppliers contribute
What Babaza says about metallic foils on polcore mouldings makes a lot of sense as metallic foils won't stretch as much as purely poymer foils before the foil breaks. Useful information from Babaza.
- Interests: .
If you do opt for wood, maybe use an exterior preserver (Ronseal etc) They do a lot of colours these days.
