Newbie Advice
Ask for and give assistance
Newbie Advice
Postby ShapedByLight » Wed Feb 06, 2019 1:12 pm
I am sure you all know the answer to this, but some advice for a beginner please.
I have a client who wants to paste canvas poly cotton directly onto hardboard backing boards prior to varnishing and framing, I have tried using PVA applied with a roller to the board but this has not entirely been successful as the prints bubble and can easily peeled off.
Any suggestions would be welcome (clean ones anyway!).
Joe
ShapedByLight
Organisation: Shaped By Light
Interests: Photography Framing
Mainline Strathdon
Re: Newbie Advice
Postby prospero » Wed Feb 06, 2019 1:22 pm
Stretcher bars? :D
Canvases are frequently glued down to boards, but it's not what are designed to do.
If the canvas 'look' is called for, print them on paper. Drymount to board and laminate with canvas textured film.
Re: Newbie Advice
Postby prospero » Wed Feb 06, 2019 1:23 pm
Welcome to the Forum btw. :clap:
Re: Newbie Advice
Postby David McCormack » Wed Feb 06, 2019 1:30 pm
Welcome to the forum :handshake:
IF this has to be done then it can be done successfully. You need to apply plenty of wet glue and get the canvas print on quickly before any of the glue starts to dry out which can cause the bubbles. You then need to weight it all down overnight.
Are these inkjet canvas prints? Better to print with enough border to stretch on bars as prospero suggests :D
www.davidaustinmccormack.co.uk
David McCormack
Organisation: Framing
Re: Newbie Advice
Postby ShapedByLight » Wed Feb 06, 2019 1:39 pm
Thanks for the advice. I have printed on canvas paper for the client for samples which would make it easier all round. I have also suggested that the canvas should really be on stretcher bars but she insists that's how her previous defunct framer had done them. I was wondering as the stock is a polycotton that the PVA being waterbased is not taking to it?
BTW Thanks for the welcome :D
ShapedByLight
Re: Newbie Advice
Postby prospero » Wed Feb 06, 2019 6:39 pm
I think you are right to be concerned about the adhesion to a plasticy surface. :roll:
The previous framer is defunct is he? :Slap:
I used to laminate (paper) prints on hardboard more than 30 years ago. Coarse canvas texture.
Still got some of them and they are as good as the day I did them. :D
Re: Newbie Advice
Postby lansonframe » Thu Feb 07, 2019 1:19 pm
We mount inkjet canvas prints onto 6mm mdf all the time .
Plenty of PVA glue applied with a roller - but you need to get the canvas on pretty quickly !!
Smooth out all the bubbles etc but we then put it through a cold roller which really helps the binding process.
We have in the past used a hand roller which works fine for smaller prints but when you get to larger pieces the rolling machine is a godsend.
We also print on a poly/ canvas blend which takes to the glue fine but we varnish the prints beforehand . :D
lansonframe
Organisation: Southgate Studios
Interests: Photography , Rugby
Re: Newbie Advice
Postby Justintime » Thu Feb 07, 2019 2:57 pm
Why not use Dry mount film in a Hotpress? It was talked about on the recent Hotpress training day in Bristol.
Steve Goodall said that the drymount film acts as a barrier between the work and the MDF as well.
Organisation: George the Framer
Interests: Art photography gardening framing
Re: Newbie Advice
Postby thecreative » Thu Feb 07, 2019 10:45 pm
I mount 370gms inkjet canvas onto 6mm mdf board cut to size prior to painting on with acrylics, good quality acid free pva with decent layflat quality, plenty on the board, spread with a card or spatula especially on the edges, then a hand roller to work it down flat.
Works a treat no great mystery and cost effective - I only work up to A2 so over that you may need one of the techniques mentioned earlier.
thecreative
Organisation: The Creative Art Company
Interests: art
photography
renovation
Re: Newbie Advice
Postby ShapedByLight » Mon Feb 11, 2019 2:50 pm
Thanks all for the advice.
I will have another go with the PVA and see if its my deficient technique that's causing issues. The prints are 990 x 300 so a little tricky to handle.
The dry mounting would be perfect but I don't have the space and the money at the mo to put one in. I did find in the odds and sods that came with the equipment some self adhesive rigid pvc foam board so might have a go with that too, but I suspect this might be a pricey option!
ShapedByLight
Re: Newbie Advice
Postby prospero » Tue Feb 12, 2019 1:55 am
I've mounted many canvases using PVA. The key thing is keeping it under pressure while it dries. Release paper and
a foam blanket will ensure even pressure. Smaller ones I put in my venerable hard-bed press (no heat). Larger ones
I use two sheets of 3/4" chipboard with piles of books on top.
I would check the adhesion on the canvas first by sticking down a scrap bit and then trying to peel it off. :wink:
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
