Help with 'pinning'
Posted: Mon 25 Feb, 2019 7:06 am
by Gingernix
Anyone know how to do this? Are there special 'pins'? Grateful for any advice
Re: Help with 'pinning'
Posted: Mon 25 Feb, 2019 10:56 am
Good Luck with that.
I've moved this to Help.
Posted: Mon 25 Feb, 2019 2:09 pm
by poliopete
I am a big boy now so I am not afraid of critique
so hear are my thoughts.
I am not certain what this is but it looks like what I would call "Tatting" If so, I have, in the past, lightly tacked this type of fabric mainly across the top on a suitable mountboard as the main support. I would use one of those rounded point needles and use a thread/cotton that is the same as the item as possible.
If you use this method a thimble is a must you may even need to start the hole off with an awl. On occasion a fabric covered mountboard may be an option. Discuss this with customer. I have made the mistake of making my stitches to tight and that will distort the item.
It's been a very long time since I framed such a thing and if anything else comes to mind I will post.
In the meantime I hope I works out well for you.
Posted: Tue 26 Feb, 2019 11:05 am
by Jules007
What is holding them up at the moment? They look like pins and very thin rods. Is this not enough to support them?
Posted: Wed 27 Feb, 2019 4:52 pm
by caro
Are they individual pieces lying on a piece of glass? - Is it free machine embroidery on dissolved fabric? If they are made of thread, then you could stitch as unobtrusively as possible, to a fabric backing, using a similar thread, then stretch the fabric backing over a piece of conservation mountboard and either have a double, shadow mount or spacer under the rebate. If the customer wants this kind of shadow effect created you could attempt to stitch the pieces to a piece of organza, or ask the customer to do that. then you could fix the organiza to a stretcher frame, possibly with staples, and frame that within a deep frame with a spacer. not a two minute job! hope that helps, good luck.
Posted: Wed 27 Feb, 2019 4:56 pm
by caro
Sorry, I've just had another look and see that each piece is spaced away from the backing on 'stilts' What is the customer expecting ?
