Replacing broken glass
Ask for and give assistance
Postby Rainbow » Fri Mar 08, 2019 11:51 am
I've been asked if I could replace some broken glass in an aluminium frame, approx 30 x 40cm. Having taken it apart, I can see that the lip on which the glass would rest is only about 2mm. The previous glass was sealed in place with strips of resin.
I usually leave a bit of "give" between the glass and the frame, but with this job, I think the glass would have to fit pretty tight up to the frame so that it didn't slip out. Am I being unnecessarily concerned about fitting the glass so tight?
Rainbow
Organisation: Picture Sales & Framing
Interests: Picture framing
flagshipframing.co.uk
Re: Replacing broken glass
Postby JFeig » Fri Mar 08, 2019 12:18 pm
The job is abnormally labor intensive. A rabbit of 2mm just not enough. It is time to get a chisel and hammer to remove the resin and make a properly wide rabbit. then there is the possibility of having glass crack later due to not having 100% of the resin removed.
Or
You have to sell them a new frame as the labor to remove the resin will be more than a new frame.
Postby Rainbow » Fri Mar 08, 2019 12:26 pm
Thanks JFeig, although I wonder if I've used the wrong description in calling it resin as it's come off very easily and it was soft and pliable. The glass was sort-of pushed into it. Sorry about that.
Rainbow
Postby poliopete » Fri Mar 08, 2019 12:41 pm
That sounds like a tight fit (2mm)
If I remember correctly, you have your glass cut a local glass merchants. I may be a good idea to take the frame to them for measuring.
FWIW I have always replaced broken glass, mounts and repaired frames in fact most anything that comes along but as Jerome and others have said "make sure you charge appropriately"
Peter.
poliopete
Postby Rainbow » Fri Mar 08, 2019 1:07 pm
Thanks, Pete. I'm happy to cut glass up to 24 x 20" so this one wouldn't be a problem. I get larger pieces cut locally though.
Rainbow
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
