Glass
Posted: Sun 10 Mar, 2019 2:14 pm
by Benhen
Old subject, apologies, but can anyone recommend glass for a 50X40cm oil. Requirements: cheap, easily cuttable, no tone and very little reflection.
For a dark toned oil painting. UV is not a big problem as the oil pigments are robust.
With thanks,
Ben
Robo, am hoping for info and your good experience.
Re: Glass
Posted: Sun 10 Mar, 2019 4:53 pm
by JFeig
Anti-reflective glass is a premium value-added glass. So is low iron glass. Both are much costlier from the glass mills than basic float glass. The glass mills and/or converters start with basic glass (regular or low-iron) and then add hi-tech coatings. it is 2-3 times the price of regular glass.
Re: Glass
Posted: Sun 10 Mar, 2019 6:13 pm
by YPF
You are asking for a quality product yet want it cheap - not always compatible.
If you are prepared to pay and to avoid wastage why not get Wessex or Centrado to supply a piece cut to size? If you are not worried about high UV protection then something like Centrado’s AR 70 would probably be OK.
Also consider a suitably deep spacer to keep the glass off the painting.
Re: Glass
Posted: Sun 10 Mar, 2019 7:13 pm
by Benhen
Thanks, YPF.
TBH I'll probably just stick to normal glass, the priority stuff being so expensive... people quite like looking at themselves after all.
Regards to the doggies.
Re: Glass
Posted: Sun 10 Mar, 2019 8:03 pm
by kuduframes
Benhen wrote:Thanks, YPF.
Just checked the Wessex cut to size calculator, a piece of 40*50cm UV70 comes in at £11.80 (plus vat and delivery of course)
Re: Glass
Posted: Mon 11 Mar, 2019 2:12 am
UltraVue 70 good as anything on oils.
The cost?
I charge roughly x10 the cost of std float. Sounds drastic put like that.
My prefered pitch to a customer is that it may add say, £30 to the cost, but the main reason you have a painting/print/whatever
is to
look at it. The AR glass allows you to see the thing better, thus derive more enjoyment from it and therefore get more of
your money's worth.
If you have it on the wall for 20 years that's £1.50 a year. What can you buy for £1.50?
Re: Glass
Posted: Mon 11 Mar, 2019 9:38 am
by Benhen
Great so uv 70 is the way to go.
Mind, two years ago at the Manchester art gallery, sitting in their caf, surrounded by lovely paintings.... except every single one of them was peppered with little green spots, about the size of tennis balls. It was the non-reflective glass in the frames turning the cafe’s reflected lights into tennis balls! Not a good look
Glass
Posted: Mon 11 Mar, 2019 9:43 am
by Bobble
For £1.50 you can get curry sauce for your chips or 30 Flying Saucers!
Re: Glass
Posted: Mon 11 Mar, 2019 10:12 am
It's not
Non-Reflective. It's
Anti-Reflective.
Pot-Noodles at my local Co-op cost more than 1.50.
Re: Glass
Posted: Mon 11 Mar, 2019 10:20 am
by Benhen
Prospero, ur a pedant, but we love you
Re: Glass
Posted: Mon 11 Mar, 2019 12:15 pm
Re: Glass
Posted: Mon 11 Mar, 2019 1:06 pm
by JFeig
Re: Glass
Posted: Mon 11 Mar, 2019 1:37 pm
by YPF
Jerome,
Like they said - “never work with children or animals”
One of my dogs will wait at the start of an agility run and when I give him the command to start he will just sit there looking at me!
Re: Glass
Posted: Mon 11 Mar, 2019 4:08 pm
Years ago, it was common to use a scooped liner rather than a flat slip, which had the benefit of spacing the oil painting further away from the glass and preventing the oil outgassing when continuing to dry out over the years and depositing a ghost of the painting onto the inside face of the glass.
Re: Glass
Posted: Mon 11 Mar, 2019 4:18 pm
by Benhen
Interesting, Mark.
Reminiscent of the way new perspex magnetically sucked acrylic paint from the surfaces in the ? 60s/70s.
