double rebated
Ask for and give assistance
double rebated
Postby Compomouldings » Mon Mar 11, 2019 11:40 am
Hi, I need to make a triptych frame for a customer.
Does anybody know where I could find a double rebated profile like the one attached
Many thanks
Mark
Untitled (1).jpg (393.75 KiB) Viewed 217 times
Compomouldings
Organisation: Compo mouldings ltd
Interests: Framing
Mainline Strathdon
Re: double rebated
Postby Compomouldings » Mon Mar 11, 2019 11:41 am
sorry the image is not to scale!
Compomouldings
Interests: Framing
Re: double rebated
Postby prospero » Mon Mar 11, 2019 12:10 pm
The only moulding I have ever seen with a back-to-back rebate is a Rose&Hollis one, but it's not symetrical and
has a reeded face. Never seen one with a finish.
I think your best option is to get some milled up. Some timber yards will do small quantities for you. I had some done by my
local Jewsons once. Or you could contact Norfolk Mouldings - I think their minimum run is 100ft.
Or glue two bevelled liners together.
Re: double rebated
Postby YPF » Mon Mar 11, 2019 1:39 pm
Just curious how you would join the vertical dividers to top and bottom rails.
YPF
Organisation: Your Picture Framer
Interests: Dog agility with my 2 cocker cross spaniels and a bit of woodturning
Re: double rebated
Postby Not your average framer » Mon Mar 11, 2019 2:49 pm
I had a quick look at a few timber mouldinds companies, but I can't find anything available "off the shelf" and if it's only for the one frame, it's not really an economic course of action to get a batch on moulding made to order. However, it's not an impossibility to run off a profile like that on a table saw with a fine toothed blade.
I'm quite amazed how good the finish is that I can obtain from my table saw, when cutting Obeche with a 10" diameter 60 tooth blade and it does not take much effort with a sandpaper block to lightly clean up the wood afterwards. This might be a practical option worth considering, if the already have a table saw. Wood types that are harder, or have a more obvious grain will probably be a lot more trouble obtaining the same finish.
I'm curious to know, how you intend to cut and join this moulding to make this frame, as I've been looking into ways of making little compartments within box frames, similar to printers type trays and as yet have not come up with an easy way of doing this. Perhaps you've got a technique that I've missed.
Re: double rebated
Postby GeoSpectrum » Mon Mar 11, 2019 5:18 pm
I made something similar recently and made something up on the router. If you have one or know somebody with one it's easy enough to cut the rebate, it gets trickier if the moulding is shaped. You might want to select a flat/square moulding if you have that option.
Plain wood frames, Inlay/tray frames and painted frames for artists.
Twitter: @AshcraftFrames
Our Blog: http://ashcraftframing.wordpress.com/
Doing nothing is a much underrated activity
GeoSpectrum
Interests: Framing, cycling, Family, x-country skiing, wine, art
Re: double rebated
Postby JFeig » Mon Mar 11, 2019 7:41 pm
Mark, you are on target, it is a custom moulding job.
As for how to join, look at how multi-pane windows are made.
As an example https://www.youtube.com/watch?v=yXEI0O2QdUA
Re: double rebated
Postby Not your average framer » Mon Mar 11, 2019 10:02 pm
Thanks Jerome. It's an idea that probably needs adapting for joining the narrow dividers, but it's got potential.
Re: double rebated
Postby Steve N » Tue Mar 12, 2019 8:13 am
Could try a local joiner who makes wooden window , it very similar to the 'Muntin' of the window, goes around all the small bits of glass
"Just because you seen it on the internet, does not make it true or right" -Abraham Lincoln
Re: double rebated
Postby GeoSpectrum » Tue Mar 12, 2019 8:42 am
Back to back narrow moulding or slips?
GeoSpectrum
Re: double rebated
Postby Not your average framer » Tue Mar 12, 2019 10:31 am
The suggestion of using a router could be quite easy if you have a means of tllting the router. Long straight router bits are easily obtainable as they are commonly used on kitchen work tops and there still would be plenty of usable router bit available after tilting the router. I suspect that getting a length of timber machined up to order would not be cost effective and would adversely affect the affordability, or profitability of the job. There will be different opinions about this, but I would seek to do this "in house" to at least keep all the profit margin within the business.
There are a good number of members on this forum who have invested in various woodworking machine tools to extend their capabilities and the range of work that they can undertake. For those who consider themselves competent to do this sort of thing, it can be a logical extension to what they are already doing and if you are wanting it, another way of attracting customers who need something special produced as a one off, creating extra profitability for you business.
Naturally, I favour doing this with a table saw and a bench top belt sander using a fine abrasive bend just to clean up after sawing, mostly because I already am set up to do this and I would not need to make any jigging to do this, but there will be other ways of doing this, if you need to.
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
