Is there any method of cleaning the acrylic glass type sheets within a frame? Once I remove the protective coating it almost instantly attracts dust and debris that I find impossible to clear more so once the panel has been inserted into the frame. I'm not sure if there are mini sticky rollers smaller than a standard lint roller? I'm sure most of you prefer glass more than the plastic fronts but i need to use this type in a specific frame I use, so if you can give any suggestions as to what could be best.
