Pearl or pearlescent moulding
DEEPJOY
Post by DEEPJOY »
Hi All
does anyone know of a Pearl effect moulding from any of the suppliers?
Regards
Re: Pearl or pearlescent moulding
Depending on the shape, the best way is to get some cheapo moulding and spray it with a rattle can of
auto paint. The metallics are available in a huge range. I think you can get pearly paint.... :roll:
(Try a bit first)
you can get pearlescent or glitter vinyl, you can vinyl wrap the moulding before cutting to lenght , I would over cut each length by and 2cm ,then wrap the moulding then cut to finished length
https://www.mdpsupplies.co.uk/categorie ... -films.asp
https://www.mdpsupplies.co.uk/intense_sparkles.asp
Might seem expencive, but the roll are around 60cm wide so on a 90x90 cm frame you could easily cover for less than a tenner + P&P
This is some vinyl I applied to some moulding around 12 months ago, it's still on there and looking fine, I think that you could do the same with pearlescent or glitter vinyl and it would work
DEEPJOY
Post by DEEPJOY »
Thanks Gents you are two of my heroes :clap:
Rainbow
Interests: varied
Post by Rainbow »
Wow, that looks stunning, Steve :clap:
I've looked at the MDP web site and there are some great vinyls there. I assume you apply it to bare wood mouldings but is it easy to apply? I can envisage getting air bubbles or creases in it.
I applied that to a finished moulding, that one was one of the PRAGUE range from Simmons, I used a finished on as the finish is nice and smooth, the vinyl is less than a 1mm thick , so need a good finish otherwise the grain would show
Rainbow
Interests: varied
Post by Rainbow »
I never cease to be impressed at what some people achieve!
