pnuematic guillotine sticking
Gingernix
Organisation: Arran picture framers
Interests: Framing Ceramics Reading
Post by Gingernix »
Hi Folks,
Can anyone help? My ancient pnuematic morso guillotine is sticking - the head wont come down - seems to be sticking but there is nothing in the way?
Pl
framingengineer
Organisation: Leicestershire
Interests: Flight simulation, recording, staying as far away from framers as possible........... sorry farmers.
Re: pnuematic guillotine sticking
Post by framingengineer »
Ok
Usually this can be caused by a number of issues.
Blades binding against the bottom set of knives....is a common one but on older machines it is usually the main cylinder seizing up/drying out.
remedy is to remove the cylinder, strip it down and clean and grease before reassembling.
If you have a very old Morso H there can be an issue removing the the main distributor connector so be careful.
Give me a call if you want to discuss this...!
Neil
neil@framingengineer.com
07793709123
Gingernix
Post by Gingernix »
problem resolved thank you
