I have a cassese cs 88 with a jammed wedge I have tried following the instructions in the user guide
block h for released
any suggestions.
Sharon
'Using the 3mm Allen key, loosen the locking screw of the wedge distributor Block H.
- Then lift the top presser’s bracket arm by hand. The wedge distributor will come out of its
housing. Remove it from the machine.
If you have any difficulty to remove the block H from the machine, push down
with your hands the top presser’s bracket arm.This should free the block H that
is stuck with the hammer'
jammed wedge
- Organisation: Rhiannon Framing
- Interests: Framing, reading and being a mum of 3 keeps me fully occupied
Re: jammed wedge
have you managed to get the block out?
If you have then if you loosen the four allen bolts the wedge should drop out. I would also give it a tiny bit of grease before you try and put it back. They can be a bit problematic putting the block back getting the hammer to line up but a bit of waggling about of the big rod that the hammer is attached to should get it back in.
Hope that helps
Hope that helps
Re: jammed wedge
thank you so much, cut hand but fixed underpinner!!
regards,
Sharon
regards,
Sharon
