Post
by Not your average framer » Mon 11 Jan, 2021 1:05 pm
Hi Sparky,
There's plenty of second hand equipment about at the moment, so I would suggest that you consider, wether you are going to be looking at new, or second hand equipment, as this will have a significant difference up on how much money you will need to get started. You will also need to choose how much equipment you are able to sensibly be able to fix in to you available workshop space and your stock of materials will require space for storage as well. There will be a lot, that needs to be considered before you are able to get things started.
I you have said, that you are not a framer, it is probably a good idea to good on a proper professional level training course, to get a better understanding of what will be involved and what level of equipment will be needed. You won't become a top class framer overnight, nobody does that! It takes time and there is quite a lot to learn. Most of us, who are already existing framers, we tell you that it a steep learning curve, but if the rest of us where able to do it, you should be able to do it too.
What you need to spend getting the necessary equipment will to a very large extent depend up on the level of capability that you intend to offer to you customers. So you will need carefully consider this, before you can make a list of the items that you will be needing to get. There are many members on this forum, who are operating their framing businesses on various levels from small and fairly basic to large and very comprehensive, with various different levels in between. May I suggest that you ask a few questions on this forum and see what answers you get from different members to help point you in to the right direction. I see that Wessex Pictures has already been mentioned and I use them to, so I have no difficulty in recommending them too.
