Air canisters
- Rainbow
- Interests: varied
Air canisters
With no customer framing to do, I've been reading the new Lion catalogue from cover to cover
Are these air canisters any good?
https://www.lionpic.co.uk/p/33906/Spray ... osol-400ml
Dust is a constant problem. I did a poster job recently which was largely solid black, and as somebody observed a long time ago, flumbs are black when they land on a white background but mysteriously change to white when it's a black background
I'd be interested to know if anyone's got any experience of the Dust-Off or similar.
- Organisation: Photofusion
Re: Air canisters
If you don't have a comprepssor, then probably.
I assemble very few frames, but when I do, they are often big, and for a regular gallery client, I dissassemble and fit work we've printed and mounted. On a single 1000x1500 frame, I can easily empty the 20l compressor. 10% goes on the print surface, 40% on the glass, and the rest, pre dusting the insides of the frame.
Also useful for cleaning pocket lint out from the 3.5mm headphone jack, and charging socket of mobile phones.
Re: Air canisters
Sorry to put a spoke in the wheel but I would never use compressed air anywhere near artwork.
Rapid movements of air will stir up dust and can even damage art. To my mind, the last thing you need
while doing the glazing is and atmosphere full of floating bits. Sharp eyes and a soft brush and patience.
Re: Air canisters
Same here as prospero just a soft brush, that way you are in control of where the bits go
Re: Air canisters
I've never had any need to use an air canister, or even felt the need to try one. Why does it make any sense to use one for removing dust paricules from inside the frames in this way. A brush has always worked just fine for me. I am amazed that people are paying as much as £7.42 for a 400ml can of "Dust off" which is little more other than fresh air. Sorry it does not make much sense to me.
My brush was not only cheaper than that aerosol can, but the brush has lasted my for many years. How many of these cans are needed by the average framer during a year? It sounds like a lot of money to me. I don't understand how that is going to boost your profits?
Re: Air canisters
Spoke accepted.
In my case, it is large prints on Baryta paper, mounted onto 3mm Dibond - even when dry, they are scarey fragile, but a mid powered air jet causes them no harm. Some of the frames I've put the mounted prints into, I've met 2, 3, perhaps even four times, and the Dibond loves to generate little wood pflumbs.
I guess I'm an outlier - my work is printing, mounting and laminating, so I like to keep things clean, so there is minimal dust to be kicked up - I don't actually get to play properly with wood.
As an aside, we have a couple of scanners here that I maintain. The Imacon 949/ Hasselblad X5 needs regular cleaning with low pressure air. Clean and mop the HDPE work bench surface with IPA, then apply a sheet of (signmaking) application tape, face up on the bench. Compressed air blows the dust off and down, which then bonds with the app tape . Have used this on a couple of ocassions with smaller frames that have needed assembly. Perhaps I should get a brush, as the oilfree Bambi is damnably loud.
- Rainbow
- Interests: varied
Re: Air canisters
Thanks for the replies. I can see how using a brush on the inside of frames would work, but on glass? By the time you'd got to the other side of the glass, hasn't the dust settled again on the first half? Unless you've got a very big brush
- Interests: .
Re: Air canisters
A gentler bit of air can be had with one of those photographers' blowers.
https://www.ebay.co.uk/itm/GENUINE-VINT ... Sw-4BXYveH
- Organisation: Framed By John
- Interests: Framing, Football, Cricket, Movies
Re: Air canisters
And there was me getting myself one of these and a dry air oil free compressor! Honestly though probably one of the best things I’ve bought - the anti static action as well as the high speed air makes cleaning a job a breeze - it’s sped up that part of the job three fold!
- 18F046D9-81EB-4FC9-B011-435108F8CDAA.jpeg (29.83 KiB) Viewed 8229 times
- Framerpicture
Re: Air canisters
is that an anti static gun Jayvee?
Re: Air canisters
Oh, that is. Looked into them years ago, but got distracted.
All the man made materials I work with, particualrly Forex Classic, and DiBond are static bunnies, worse still when you peel the release film off.
I need one of those guns in my life.
And some tinsel.
And it would be a massive boon for the scanners - freshly processed film is nice and clean, but older negtives could definately do with a gentle waft from a kilo(V)Bambi.
And speaking of scanning, I think Richard Kenward is based in your town - a true master of scanning and art repro.
And some tinsel.
Re: Air canisters
Yup it’s an anti static gun!
Cost a bomb along with the Bambi VTS200D. But I’d do it again! I’ve only had it a month or two...not the best timing due to the current situation. That money could have been better spent I suppose now looking back at it - but we obviously didn’t know what was around the corner!
I’ve wanted one for years - and I’ve keep putting it off/forgetting about it/thinking it was a luxury...I think it’s pretty essential now!
Richard Kenward - he’s a customer of mine - well he was - he’s moved to the Isle of Wight! Lovely chap!! Mind he did have me make something and get it shipped out to him a while back!
- Framerpicture
Re: Air canisters
Thanks for the response Jayveee, which model gun is that? Its something I've long considered
Re: Air canisters
It’s a Fraser 4125 and supplied power transformer too...not cheap by a long way...but I honestly think well worth it! On the limited items I’ve been able to use it in before shutdown!
You should be able to get them from any clean room supplier - I got mine from Sensemaster in Chepstow.
Re: Air canisters
Well that's the reason not to use compressed air,you just blow the dust everyware, then it will settle everywhere
The way I do it is like
Have the artwork ready to put in the frame
Clean one side of glass,
Flip glass over and clean this side
Place artwork face down on the glass, also placing any barrier board on the back of artwork, and backing board
Now flip the whole lot over, check for and dust etc under glass, if any clear out
Now is the time , if you seal your framing packages to do it if not skip to the next step
Place frame over the whole lot, flip back over and fix back with chosen method
Flip back over, should be looking at the front of the frames picture, now final check for any dust etc, if none
Flip back over and finish the back off, tape up and add hangers and cord
- Rainbow
- Interests: varied
Re: Air canisters
Thanks for that, Steve. I do similar but instead of putting the artwork on to the glass, I lift the glass up to inspect it after cleaning and then put it down on to the artwork. I'll try doing it your way. Also, I've been using Tork lint-free tissue to clean the glass, together with a glass-cleaning spray. The tissue isn't supposed to break up when damp but mine does, so I might be using too much spray and making the tissue too damp.
Re: Air canisters
I use Tork wipes from Lion , mine always break up, but when they do, I either refold them or start a new one, one of the reasons I don't pick up the glass is , if you pick up then put down on the work, you are putting the surface (of the glass) which was touching the bench covering (carpet on mine) onto the artwork, which could now be wet, from the overspray of the glass cleaner or picked up bits from the bench, and transfering to the artwork, the way I like to do it, I'm putting the artwork down onto (hopefully ) dry and dust free surface, well most of the time anyway, also when picking up the glass, you could also put finger marks on it
