Silicone
PVA Adhesive works "wonders", apply a liberal dose all over the back of the picture then it can never be removed! Permanent!
also, Guillotines are excellent for straightening up those frayed ends, and making the hand made paper look straight and perfect.
for good measure, stick mount to back with Elastoplast...
it's the way all GCF's have been trained !
Hi Ken
If you search through the Grumble you will find some sound advice about mounting Papyrus
http://www.thegrumble.com/search.php?searchid=109882
Silicone and some of the suggestions by the other posters may not be the best methods.....for mounting a Papyrus...
Enjoy your ramble around the Grumble there is some very sound advise available there.....
Another place to have a look is the archives of the Picture Framing Magazine http://www.pictureframingmagazine.com/a ... index.html
Good luck
Good luck
Surely wallpaper paste would be the first port of call.
1. It's cheap
2. Sticks down wallpaper pretty flat. Must do the same with a bit of old papyrus
3. You can finally get round to doing the spare room with the extra 15 litres you made up, hence pleasing the wife no end.
Win vs win situation if you ask me.
1. It's cheap
Am I missing something here?
I've been leapt on for leaping on others - now everyone's at it - bar Dermot.
Anyway - tourist papyrus' = CARP - who cares how you stick them down - chances are the customer has seen them framed against the glass and wants the same. Fixing method in that case is pretty irrelevant.
But if you want to do a nice job - spaced from the glass - use 'S' hinges or even micro dots of archival paste. Sometimes also the customer does not like the 'tatty' edges and wants it all neat and squared off, just like everything else in their neat and square lives - in that case, hinge it like anything else.
Bound to be a shedload of info on Dermot's links though.
Thanks everyone
I would normally use dawing pins on all four corners but could not find any.
So i suppose staples will have to do now.
Do you think they might scratch the glass..
Tried no-nails didn't find it gave it that special effect but thanks for that.
Elastoplast good idea never thought of that one i can always say who recommended it to me hope you don't mind.
Wallpaper paste bloody hell wish i had asked this question a week ago just finished decorating. At least i can now tell the customers only bring in there stuff when i am about to re-decorate should save time and money
thanks for all the info.
food for thought there at least nobody take the p..s out of people on here.
- Organisation: Hampshire Framing
- Interests: Golf, DIY and baking bread,cakes, biscuits and making chilli jams and various chutneys.
You just happened to put your head above the parapet and it got shot at.
Personally I would not have a papyrus on my wall, but those who bring them back from wherever think they're fantastic.
About a month ago I framed a 6ft by 2ft piece. Customer was over the moon; what I thought didn't matter, as with a lot of things that come through the door.
Smile, be affable and be professional.
Never trim; the edge is all part of the final effect,and allow a space between glass and papyrus, otherwise it will look like a prune.
Measure twice - cut once
