Best type of material for mounting and cutting bench
- Organisation: TBC
- Interests: Writing, design, vintage furniture, surfing, education
I have bought a large Danish teak desk with built-in AO chest plan and my husband is kindly making me a marginally larger section to go on top of it which I will need to cover with something - part glass-cutting/part-mounting/part assembly.
What is the best type of material to buy to cover it? And does anyone know the best place to buy this material? Is it carpet? Is it a blanket? Or is it something else?
Would really appreciate advice/your opinions on this.
Many thanks
Jane
Many thanks
Jane
Re: Best type of material for mounting and cutting bench
I would use carpet for glass but I use sheets of 3500micron mount board to cut on or buy a cutting mat.
- Organisation: TBC
Ok thanks that sounds great.
- Organisation: home
- Interests: cars
I use grey dry mount board, always have done (18years) , never had any issues, it's good for cutting on, cheap enough to replace, which tends to be the same board over and over as I always cut in the same place, good for glass too as the dust/splinters rarely get caught in the surface, just brushes clean.
Can't comment on carpet, but it seems to work for lots of people, maybe best to try a couple of methods to find which you prefer.
Sorry I have just re read what I have written I should have said
"but I use sheets of 3500micron mount board to cut Mount Board on or buy a cutting mat."
I have always used kitchen carpet. But avoid jazzy patterns and strong colours as they makes your eyes go funny under bright lights.
Carpet is great for working face-down on frames. Any hard surface - inc cutting mats and cardboard can scuff frames.
This really should be in General Discussion - I'll move it.
we cut glass on a wall mounted fletcher, then put it down on a bench covered with Router matting which is friendly, and the holes in it catch any bits. The mats are regularly pulled off, shook and replaced.
we cut mounts on a self healing cutting mat.
we assemble on a bench covered with display board, taped down with brown tape, but again use router mats over the top to prevent any damage to the face of the frames.
But, I have lots of room
If I used only one bench then I'd use router mat, and cover it with a cutting mat when required.
this is an example of router mat, but I got the last ones from B&Q when they had a sale on
http://www.rutlands.co.uk/sp+woodworkin ... tAodIkkAsg
Not a good idea to use a surface for combined glass cutting/frame assembly - glass crumbs could cause problems.
- Organisation: TBC
Thank you everyone for your advice.
My table is very long - 3m - so I am positioning my mountcutter down one end, and propose cutting glass at the other end. Frame assembly will be in the middle. Unfortunately I don't have the luxury of space or money to invest in any further tables right now. I am just starting out...
I cover a my benches with Solid Kraft backing board (the type that is brown kraft lined on both sides).
- Interests: 4 or 5 ...
carpet here, also a cutting mat set into one carpeted bench for hacking and slashing at things.
if you can manage to keep the the room you want, keeping separate an area for glass-cutting only, that sounds ideal. glass crumbs will get all over the place and into the carpet and cause all sorts of misery.
Failing that sheets of artbak or greyboard and brush it clean between glass cutting and other work, or work in batches.
Fortunately I rarely need to cut glass on the workbench, as I have a System 4000 wall mounted cutter, when I do need to cut glass on the bench I have a piece of left over carpet which can be laid on the bench top.
i dont cut glass on a bench, use a wall cutter
but my 2 benches
1 - 8mm toughened safety glass - great for cutting trimming etc on and my underpinner is against it, which means any glue etc on it wipes great very very easily
my other bench has a piece of 5mm foamcore on it with rubber drawer liner from ikea stuck to it
fantastic for cleaning glass and assembling, and cheap as chips, and easy to clean debris off
but my 2 benches
I like the idea of the 8mm toughened glass!
