Moulding chevrons
simoonez
Organisation: Dorset Framing
Interests: pasties
Moulding chevrons
Post by simoonez »
Has anyone tried displaying moulding chevrons using sheet metal and strip magnets?
I want to display them without using velcro if I can. I guess my main concern would be that strip magnets (as in the flexible stuff) aren't amazingly strong. Sheet metal cut to size is quite readily available online, and not too dear.
If anyone's tried it it would be good to hear if it worked or not.
Uncle Sumo
Re: Moulding chevrons
Post by Uncle Sumo »
Why no velcro?
Sean
chris62
Organisation: Sansom Gallery
Interests: Photography/Carpentry
Post by chris62 »
I think you will find that the heavier mouldings would slide down
Well put those at the bottom then :roll:
silvercleave
Organisation: thought I was
Post by silvercleave »
Velcro is ok but when the customer wants to put it on a delicate cross stitchyou have to be quick to stop them, magnets make sense, I'm sure if you put a large piece of magnet on they wouldn't slide, they can be purchased in sheet form and is cutable with scissors
You can get rare earth magnets which are very strong. But enough to do all your chevs would be expensive. Plus you would have to fix which would need them sinking into all the corners so they were flush with the surface. Not a quick or easy job.
I was thinking earth magnets too .... but differently!
If you could get strips of these things and I know you can get short strips ( a lot of which would cost a small fortune but it would be once-only and they could be sunk BEHIND a covering fabric ... which could be Velcro-friendly so's you'd have that option too) they are so powerful you may well not need any attachment on your samples, the 'V' nails would be enough! (?)
chris62
Post by chris62 »
Try these people very friendly and helpful http://e-magnetsuk.com/
