No more hooking
GeoSpectrum
No more hooking
Post by GeoSpectrum »
I have had a few issues with hooking on my Ulitmat Futura. I had new workbench which was fitted last week, but one arm of the bench wasn't quite wide enough for the cutter so I took the little rubber feet off and the cutter is now sitting flat on the work surface with each end overhanging by about an inch, just enough to clear the end assemblys. Result? perfect cuts, no hooking. I assume the cutter was flexing. It is now rock solid. :clap:
22rabbits
Organisation: myown
Interests: framing
Re: No more hooking
Post by 22rabbits »
Good to know. I had this problem for awhile but dont have the same setup any more.
cebrooker
Organisation: Blunty's Mill B&B
Interests: Sport, signature collection, looking to start framing.
Re: No more hooking
Post by cebrooker »
I have had various problems with mine - it is the monster sized one, I assume this will solve my woes! Might try putting some KLB offcuts between the very large gaps.
pepper
Organisation: Stuffed Pepper
Interests: All manner of craftiness, of course including picture framing!
Re: No more hooking
Post by pepper »
cebrooker, could be a number of things happening particularly with a long machine, give Keencut a ring I am sure they have a solution for you.
