Morso vs cassese double mitre
242framer
Organisation: none as yet!
Interests: framing, football, family!
Post by 242framer »
hi all.
real novice here!
we currently use a standard foot operated morso mitre. Looking to make the process more simple and to get a better result, i have the chance to buy a casesse 939 can anyone tell me the benefits of upgrading to this machine please?
thanks in advance!
Timh
Re: Morso vs cassese double mitre
Post by Timh »
we made that choice a while ago
best thing we ever did
242framer
Post by 242framer »
Timh wrote:we made that choice a while ago
that's encouraging!
Framerpicture
Organisation: Picture Framing
Post by Framerpicture »
I would highly recommend the 939- If you have the space and good dust extraction you won't regret it :D
Mark Thornton
Post by Mark Thornton »
Mitre saw
Pro's:
Larger cut capacity
Less effort
Better quality mitres
Cons:
Larger size
Noisy
Dust extractor required
Higher cost of servicing
(may also require 3 phase power supply)
your compressor may need upgrading
Mark
misterdiy
Organisation: Decormount
Post by misterdiy »
Plus you will have problems cutting fillets and small stuff, so you will probably end up keeping the morso as well
IFGL
Post by IFGL »
Also the 939 is much heavier, it's about a 5 or 6 times heavier in fact, if you should drop it on your big toe it will smart a bit.
I think they weigh around 750kg. You'll need a forklift to unload it and unless you have a big door
it's going to be a struggle getting it where you want it.
It will pay dividends though if you cut a lot of wide mouldings. It will also cope better on moulding with
undercut backs.
