A local gallery has asked me to frame 2 cast glass baby's hand prints. About 190mm in diameter and quite heavy. They are clear glass so I can't stick them to a back board.
Gallery has suggested allowing the frame moulding to hold in the glass and using a mount behind to hold it in place. As chevron on left.
I would have to use spacers to cover the inside of the moulding and also to stop it rotating in the frame.
Any suggestions of how to frame (and how much to charge, just my time?).
Photo attached (Grey background one side was an experiment to see if a colour other than white would look better).
Thanks, Jonathan
Hand prints moulded in clear glass.
- Organisation: Letters & Frames
- Interests: Planning to add picture farming to my portfolio of creative offerings.
Interested in history - buildings, landscape, transport.
Lettering - Typography, Letter forms, Calligraphy - Contact:
- P1020882_xsm.jpg (154.36 KiB) Viewed 4954 times
Re: Hand prints moulded in clear glass.
That's one big baby!Jonathan wrote: About 190mm in diameter and quite heavy.
Melinex straps?
Presumably the interest is in the child's prints, not in the edge of the glass, so you could use an 'ordinary' window mount?
Or hold it in place with some rods/clips?
The gallery's idea with the glass discs right up against the glass sounds to me as though you will end up with broken glass.
Could be a child, but the overall size of the glass is around 190 mm diameter.
The gallery were suggesting NOT using glass, so the background of the casting would be against the frame. So a shallow box frame open to air and dust, another problem.
Jonathan
Jonathan
I've framed a few glass bits, none of them round unfortunately.
Roboframer's suggestions on this thread helped me a lot: http://theframersforum.com/viewtopic.ph ... sh#p116858
Good luck!
Good luck!
- Organisation: Framed By John
- Interests: Framing, Football, Cricket, Movies
Sink Mount? If it's not the edge of the glass that's the feature? Seems a shame to hide it mind, but then again, we can only obey the laws of physics in this job (contrary to customers belief)
I've done difficult stuff like this before and it's not as difficult as you may at first be thinking! If you stick these glass items onto a piece of glass spaced back from another piece of glass at the front of the frame, with a piece of mountboard spaced back behind it, it will look like it's floating in mid air and everybody who sees it will wonder what's supporting it.
Use clear silicone to secure it to the piece of glass, don't use little blobs as the edges of the blobs will be visible, but cover the back almost to the edge of the glass items. You only get one chance to get this right so put a bit of scrap mountboard of the same size underneath the glass, which has the outline of the glass item drawn onto the mountboard with a pencil. You will need a quite deep frame, but It will look great!
In the I think the latest edition of 4Walls mag from Arqadia, ( it's at home so can't show it) Lynn Hall (GCF (Adv.), APF
Fringe Arts) shows how to frame a number of glass blobs in a frame , she used a glue of some sort (I written glue, but it could be adhesive, just don't nit pick ) just found a link
Go to http://www.arqadia.co.uk/docpages.aspx? ... e=magazine down load the PDF of the January edition, the artical starts on page 6 of the PDF version
