Cassese clamp type
Posted: Thu 19 Apr, 2018 8:31 pm
by Ed209
I have a CS200 and have been experimenting with the various clamp rubbers and so far found the hard green round bung the best particularly as you can get away with out using the spacer bar for less tall mouldings
Just wondering what others prefer and tend to use as there default one.
Re: Cassese clamp type
Posted: Thu 19 Apr, 2018 8:51 pm
by theframer
The Green bung is for hard mouldings and can mark soft ones my default is the white triangle,
Dave
Posted: Fri 20 Apr, 2018 8:09 am
by Steve N
Mine is the yellow, very rarely do I use the green one for hard wood, must be around 6-7 years since I last used it
I never use the spacer bar if the moulding come up to the top of the blocks, never use it on any of the D&J Simons FEST range
Posted: Fri 20 Apr, 2018 9:23 am
by grahamdown
I love this one as
https://www.lionpic.co.uk/p/13263/Lion- ... or-Cassese
(a) its easy to remove whilst clamping moulding to ensure perfect alignment
(b) together with the white presser its ideal for tray frames without having to alter the height - Lions for the inner part and white one for the edge.
Posted: Fri 20 Apr, 2018 9:32 am
by Steve N
I just have a block of wood for popping to fill the gap when joining tray frames
Posted: Fri 20 Apr, 2018 9:37 am
by David McCormack
Black triangle for me, but most of my mouldings are flat/square hardwood profiles.
Posted: Fri 20 Apr, 2018 10:31 pm
by Ed209
grahamdown wrote:I love this one as
You lost me what is the “White one” for the edge? [emoji45]
Posted: Sat 21 Apr, 2018 12:28 pm
by Steve N
Forgot to say, you can just experiment to see what works best for you, in fact that goes for most things in framing, it's how I learned, read it up in books and adapted for the way I work
Posted: Mon 23 Apr, 2018 1:20 pm
by grahamdown
Sorry for the delayed reply Ed.
the inner part of the moulding is pinned using the Lion's presser which is quite deep and the outer using the white shallow trianglular one as you just slide out the Lions one and insert the white - saves having to adjust the height of the presser arm.
