Drilling through museum glass part duex....
- Organisation: Framing Mad
Well, here is the final result, the photograph (as usual) doesn't do it justice - from some angles the spoon seems to be further forward than the mount!
I keep calling it velvet, but 'er indoors keeps slapping me round the ear and saying crushed velour. One day she'll beat it into me. It's just laid flat on the board, it has plenty of variation of sheen & colour so no need to introduce any by folding & creasing.
I get bits & bobs of the materials from ebay - a couple of quid gets you plenty enough for a few jobs.
Glass bonded three bent plastic coated hanging wire 1" lengths, so they made a loop which I could feed button thread through (which you can see on the vertical struts). It's strong enough to lift the glass by, yet if the thread fails it won't be a major job to re-tie. to stop it rocking on the wire I put some small clear rubber domes (as used for corner bumpers) in strategic places to keep the whole thing stable.
So do I and it's on my wants list.w00dward wrote:I want a cmc... :
In the meantime, however, there is a way of doing something which give a very similar effect even if you don't have a CMC, but it's usually done as a double mount as the circles in the corners have to be replaced and taped in place and the second mount hides most or even all of the rest of the circular cut out.
It's a lot easier to do on a fletcher 1100, than on a Keencut Oval six. The circle has to be in the centre of the revolving table on the Keencut, which limits the size of the mount, since the opposite corner of the mount has to clear the support in the corner of the machine while the table revolves.
I've got quite a collection of older books on mountcutting, including some by Charles and Herb Carithers, (these are the guys who did the C & H mountcutters), and a lot of things which we think of as CMC jobs were done manually in years gone by. They are still possible by manual means today, if you are willing to practice the necessary skills and keep everything tightly calibrated.
just "borrowed" and adapted your idea Spit,
we've just got 12 heart shaped coloured pebbles to fit in a frame, but they need to be removable
going to float them on Museum Glass, attached with Velcro, so they can be taken off and colours jumbled around if need be,
this glass will be floating around 5-6 mm off the mount board and the mount board will be wrapped in calico. leaving a floating effect,
a challenge you say? i like a challenge!
