Hi Everyone
Just upgraded to a morso, having used a magnolia for many years. Most things seem straight forward enough, but can't get to grip with the measuring system.......
Tried a search, and one topic seems to give a bit of advice, but still can't seem to figure it out........
Maybe it's just me thats a bit daft.......
Taken the number from the machine and contacted Morso for instruction book, but in the meantime can anyone help, making sense of the measuring system...???
If anyone can help, or if its easier for me to give them a call on either mobile or landline, I woud be most grateful......
Many Thanks
Jeremy
PS email is jeremys@blueyonder.co.uk
Morso Measuring
Your Morso has 3 scales -
A sliding scale with a mitred end, a long fixed scale and a short fixed scale at right angles to it.
The short fixed scale measures the back of the moulding, twice this distance needs to be added to your 'glass size'
The sliding scale is marked TWICE as big as it actually says - to save you doing the maths.
So - if one side of the glass size is 500mm and the back of the moulding is 25mm, align the 25mm point on the sliding scale with the 500mm point on the fixed scale.
You may find the machine is calibrated to cut sligtly larger to allow for some play.
You can ALSO, measure one side of the glass size, say 500mm, add twice the moulding back yourself, say 25mm x 2 = 50mm and set ZERO on the sliding scale to 550mm on the fixed scale.
KISS
chop end off mopulding (first cut).
slide moulding along bed so that you can measure the inside edge of rebate against the vertical scale.
take piece of white tape - tape it on the sliding part of the horizontal scale so that it indicates the figure on the vertical scale. your morso scale is now calibrated to the piece of moulding that you wish to cut. Set the size of the longest length first on the fixed part of the sliding scale using the edge of the white marking tape as the set point on the sliding scale - hope that makes it straight forward enough.
Many Thanks
Hi Everyone.....
Just thought I'd post a quick, but a very LARGE Thank You, to those that replied, namely John, Mark, Martin, and my friend from across the water....
Bet you didn't expect my life story though... .
It is much appreciated, and helped no end. Without the explanation I would still be scratching my head.....
So once again, Thanks
Jeremy
Jeremy
Mine only has two scales.......
I have a brand new Morso,but I only have two scales,the sliding angled one and the long fixed measure. Is the third an option?.
Regards,Mike
Regards,Mike
Hi Mike.
The third scale is at right angles to the long fixed scale, just afer the right cutting blade.Its recessed into the morso bed. Its the first scale you use when making a frame. it measures the inside edge of the rebate. If that scale is missing the recess should be easy to see on the bed its about 1/2 inch wide maybe a bit less. Usually if one scale is missing its the sliding scale as it can be taken off or fall off in transport.
