Vertical mitre machine with two high speed steel blades, mounted on vertical cast dovetail slides. These slides are fully adjustable to take out any wear that may take place over many years of use.
The front fence on the mitre machines is adjustable to cope with out square walls when cutting dado rails, skirting boards etc.
This machine is ideal for manufacture of small picture and mirror frames.
Standard Equipment ORC55:
One pair of H.S.S. knives
Length stop assembly
Plastic guard
Operating lever
Two hex key wrenches
Weight is approx 16kg price new is £495+VAT
Maximum cutting width is 55mm
Collect near Penrith/ Carlisle £200 ONO e mail for pics
This is an old but well cared for machine which operates smoothly with no sloppiness in the linkages
[img][http://rs129.pbsrc.com/albums/p211/trex ... t=clip/img]
ORTEGUIL ORC 55 mitre trimmer, north Cumbria
- Organisation: DT teacher
- Interests: Picture framing, wood work, wood turning
Engineering, metal work fabrication kit cars Triumphs
- 2669893F-1368-4786-9F7A-EDBA482B72DE.jpeg (143.76 KiB) Viewed 2446 times
Re: ORTEGUIL ORC 55 mitre trimmer, north Cumbria
Nostalgic!! Looks a little bit older than the model Collectors Cases produced the triple double mitres for over 300,000 glass cases. Any framer thinking of turning their hand to glass covers and picture frame cases would be well equipped with this equipment.
Bonded Glass Covers with wood capping.
Carcase Cases.
Semi Carcase Cases and modern updates of the Roland Ward method.
and 'framers' improvements on acrylic covers.
Just a few ideas to add to your list of uses
Carcase Cases.
Yes a great bit of kit!
