2.55m Board Cutter. Makes light work of cutting, trimming and scoring even the toughest materials.
Machine is fast,accurate, clean, silent
Can handle a wide range of heavy duty materials which would previously have required the use of a power saw. Thinner materials can be stacked to cut multiple items simultaneously.
The machine is a high quality production machine with a fast pneumatic clamping bar and high cutting speed, driven by a powerful motor to reach a cycle time as fast as possible.
Materials
Rigid Polystyrene, 3 mm
Cardboard 3 mm
Foamcore board 19 mm
Rigid Foamed PVC 10 mm
Gatorfoam 19 mm
Can be seen working
Sallmetall Board Cutter
- Organisation: WEMBLEY LAMINATIONS LTD
- Interests: WORK
- IMG_7734.JPG (577.16 KiB) Viewed 1870 times
- IMG_7733.JPG (523.47 KiB) Viewed 1870 times
