Gapp Canvas Stretching Machine - Up to 1.2m x 1.2m Canvas
Posted: Thu 09 Jan, 2020 10:03 pm
This machine is in very good condition and is ideal for stretching canvas with less effort and in higher volumes! With this machine you can stretch two sides of a canvas at once and can easily complete a canvas in a minute. It has been used but is very clean and in perfect working order. It will stretch up to a 50" (127cm) square canvas in a very small footprint.
I am not making many canvases these days and now concentrate more on digital wallpaper.
In summary:
* Air operated so just need a basic compressor to run
* Requires a long nose stapler -
* Use on any stretcher bar depth - quickly switch between depths
* Massive increase in production speed
* No more cutting excess canvas away from corners - nice tight stretch ensures corners are nice and flat!
* Excellent condition
Some Videos Showing the same Stretcher Machines in Use:
See more info here: https://www.canvasmaster.net/canvas-stretch-master
Dimensions wise, you would require the following amount of space, and then also a gap of around 20" or so between the machine and your bench to work in.
Length: 80"
Width: 26"
Height: 75"
At a fairly steady pace I can make 30 canvases per hour on this machine including trimming the excess canvas off the back and taping the backs of the canvas - so the whole stretching process. You can change the depth of the stretch as well, so in about 30 seconds you can switch from stretching narrow frames to deep frames. I use 18mm and 38mm bars & 45mm and it's very easy to switch, you could do this with any other frame depth as well.
These machines brand new cost £7800. I am looking for around £2000 (no VAT)
Due to the size of this machine it will need to be picked up by the buyer. I am based in Morecambe Lancashire and will need to be collected and its very heavy. We will help load in to a van.
Please message me if you want any more info. Any sensible offers will be considered.
Thanks in Advance.
Kristian
www.printedspace.com
In summary:
Length: 80"
Width: 26"
Height: 75"
Thanks in Advance.
Kristian
