Hello Everybody!
My brother has recently packed up his small framing business to pursuit a better life 'Down-Under'. Leaving me with the mind-boggling job of trying to sell up some of the final bit and bobs from his shop. While stumbling across the internet, you’d seem like the guys that may be interested in some of it. The items are all listed below and I’ve included an image along with a link to the companies website to view some more details on the item.
Postage
I can post all the items to the UK (are even worldwide), I’ve included the cost of P&P under the item price, for outside the UK please PM/email me (comagee @ hotmail.com). I will post all Royal Mail 1st Class on the same/next day.
Payment
I can accept PayPal or Personal Cheque/Postal Order. I’m very reliable and you can view my eBay account for feedback ratings.
http://feedback.ebay.co.uk/ws/eBayISAPI ... llFeedback
FrameCo. - 90° Straight Cutter
Deluxe model for 90 degree cutting
Spring loaded safety handle
Settings for mount board through to fome core board
Easy change blade
Paper, Card and Fomeboard Cutter
Includes 5 Blades
http://www.clubframeco.com/store/produc ... ?pd_id=906
Quantity: 4
Price: £18 each
P&P: £1.70
(Click on image to view larger)
FrameCo. - GrooveMaster
Decorative V-Groove cutter
Attaches to all FrameCo Mat Master rules and cutting rails..also fits onto Logan cutters
Includes unique corner gauge for accurate measurements
V-Grooving tool and Freestyle Cutter
Kit Contains: GrooveMaster tool, Corner Gauge and 6 Blades
http://www.clubframeco.com/store/produc ... ?pd_id=900
Quantity: 3
Price: £18 each
P&P: £1.70
FrameCo. - Cord Clamp
Gord Clamp with Unique flexible corners
Makes 4,5,6 sided frames
Flexible non-slip corner clamps
Exclusive corner "wings" to prevent the clamp slipping
Clamps frames up to 40 x 60cm
Used in conjunction with a glued joint
Clamps 4 corners at one time
http://www.clubframeco.com/store/produc ... ?pd_id=935
Quantity: 4
Price: £4.50 each
P&P: £1.20
FrameCo. - Steel Strap Clamp
The ideal framing clamp. The FrameCo Strap Clamp 5M - 16' holds frames up to 1.25 x 1.25M square. The metal strap enables you to achieve maximum hold but doesn't damage the corners of the moulding due to the special flexible, plastic corner pieces. Clamping is a most important part of the frame joining procedure. If you hold the frame securely then v-nailing will give you a tight secure joint.
* Features exclusive corner "wings" to prevent the clamp slipping.
* Four corner clamping allows for better control.
* Metal strap clamp for stronger holding power.
* Metal strap folds easily into holder.
* Flexible corner pieces will not damage outside of frame.
* Lays flat on the table for easy v-nailing.
Kit Contains: 5m Steel strap and 7 multi-angled corner clamps
http://www.clubframeco.com/store/produc ... ?pd_id=929
Quantity: 1
Price: £25
P&P: £2.50
FrameCo. Mitre Saw Ezy-Measure System
With exclusive Measure Mate Calculator for 45°, 36°, 22.5°, 18° & 15°, degree mitre cuts.
For measuring lenghts up to 1.15m (3.85ft).
Attaches to most manual and electrical powered saws.
Kit Includes: Support table, 4 adujustable legs, measuring scale, material stop, Measure Mate Calculator and instalation instructions.
http://www.clubframeco.com/store/produc ... ?pd_id=921
Quantity: 1
Price: £35
P&P:£6.50 (heavy item)
Fletcher 'Goldtip' Glass Cutter
Ive also got a box of 10 of these 'Professional Quality 'Gold-Tip' Fletcher Glass Cutters
Comes with a Tapping ball and 3 break out notches.
I have used these myself for some freelance design work ive done and I must say are just fantastic, compared to the cheap glass cutters.
Price: £3.50
P&P: £1.00
If you are interested in buying more than one let me know and I can work out a cheaper price.
http://www.fletcherviscom.com/hardware/ ... _pg2.shtml
Thanks very much for having alook.
If your interested in any of the item or have an questions please PM me or drop me an email at comagee @ hotmail.com
Regards,
The brother left in the cold misserable UK
For Sale: Assorted Framing Supplies
