This is from my Euro underpinner - I do have a source for spares but he's on holiday! I'm also hoping he has not had a load made but this is a stock item somewhere (I've looked with no luck so far) and/or the same thing is used in other underpinners.
Wire diameter is about 3mm - coil diameter about 27mm and overall length about 550mm "
My machine uses two of these and it's working on one at the mo' - it can't keep that up for long.
Tension spring
- IFGL
Re: Tension spring
There is a spring shop on every street corner in Sheffield, email your pic to one of them.
http://theframersforum.com/viewtopic.ph ... ng#p105898
Re: Tension spring
I've no idea how I worked that out, it's about 80mm!Roboframer wrote: overall length about 550mm "
Anyway a framer, and a Jolly Good one, has come to my rescue.
