Morso problem
Baird
- Organisation: n/a
- Interests: Fishing, Art, Design.
Morso problem
Hi all, first post on this forum and typically it's a request for help.
The pin attaching the draw strap to the bell crank lever has sheared. Does anyone know if it is possible to drift the pin out the bell crank lever. I have tapped it a couple of times but it seems solid. Before I try again, I thought it better to get advice.
Baird
- Organisation: n/a
Re: Morso problem
Actually that was my second post
Re: Morso problem
Baird
- Organisation: n/a
Re: Morso problem
Its threaded I think, the bit that snapped off should have a slot it it for a screw driver.
Baird
- Organisation: n/a
Re: Morso problem
This is the part where it snapped. It seems that the pin is just pressed in and unthreaded. I think drifting it out is the way but it's very solidly in. I may need to heat it up. There has been about 1mm of movement.
images hosting
images hosting
Baird
- Organisation: n/a
Re: Morso problem
Sorted... I swapped the bolt I was using to drift it out for the bar on the blade spanner and it eventually came out. There was a bit of rust holding it in. New part ordered so should be back up and running tomorrow.
- StevenG
Re: Morso problem
Great, glad I was here to help
