Hi, I have started up my small picture framing business and it is going well at the moment with work trickling in. I have until now been using a small axminster mitre trimmer but are now considering investing in a second hand morso or something similar
Any advice would be appreciated. When initially looking on eBay I have seen there are a few available, is this the best place to look or are there other places I should be looking?
I would be interested if anybody has one for sale or knows of one for sale, but also if you could give me some advice on what things I need to look for when buying one of these second hand?
Also are there specific models I should consider, I have seen model f advertised and also a morso mitre maker which in all honesty looks exactly the same
Any help would be appreciated, also should I consider something other than Morso, such as a Hansen or something else ??
Thanks, Steve
Morso Guillotine / Mitre Cutter
- Keadyart
- Organisation: Framing
Re: Morso Guillotine / Mitre Cutter
Steve,
if you have the space,a good first/second/third-hand Morso is the kit for you and will give you accurate mitres and identical lengths on your frame sides.
Have you had a look at the sales section http://theframersforum.com/viewforum.php?f=7 .
All the best
Brian
All the best
Brian
- Organisation: SMart Woodcraft
- Interests: Picture Framing, Furniture Restoration, Furniture Build
Thanks Brian, I think I can just accommodate it in the workshop
Thanks for the link and have had a look through but nothing there at the moment and will keep looking there as well as eBay
Thanks again
Steve
Thanks again
Steve
Morsos are pretty tough cookies. One that's has had moderate use for quite a few years will still
perform as new. The ones to avoid are ones that have been hammered and abused and done
a lot of work.
One way to tell is to see if the pivot holes on the pedal are oval rather than round.
a lot of work.
Thanks for the heads up Prospero, most appreciated. Looks like Morso is the way forward just a case of getting a good one .
Thanks for the advice
Steve
Steve
I've seen some for sale that look as though they have had very little use.
Guide price around 6-800.
If there are spare sets of blades included, bear in mind that a new set would run about 200 quids.
* I bought mine new in 1984 and it may be a bit mucky but it's still going strong. You can't have it though.
Thanks prospero some good guidance here I am definitely on the path to a Morso it's just finding a good one
It will be a squeeze to fit it in the workshop but should be able to reconfigure to accommodate
Thanks again, Steve
Thanks again, Steve
