It's a mystery!
It's a mystery!
Postby drpeej » Fri Sep 15, 2017 3:15 pm
I cut my mouldings on a Morso in my garage.
The garage measures 2.8metres wide x 6 metres long.
When I take delivery of mouldings they are stored in racks in the ceiling.
So far so good - however when I take down a piece of moulding it is almost always the wrong way round to go into the Morso. As I can't fit a full 3m length sideways it is a bit of a performance to turn it round before I can feed it into the Morso.
I would expect it to be correct about 50% of the time but it isn't.
I will have to think about it more carefully when taking it off the Wessex van and putting it in my garage :head:
Peter Harris GCF (APF)
www.framemount.co.uk
drpeej
Organisation: Frame Mount
Interests: Photography, Skiing, Cycling
flagshipframing.co.uk
Re: It's a mystery!
Postby featurepiece » Fri Sep 15, 2017 4:43 pm
Cut a little gap about waist height around the whole garage, hang the top bit from a nearby tree or high hedging.
featurepiece
Re: It's a mystery!
Postby pramsay13 » Sun Sep 17, 2017 4:30 pm
I have recently built a 5 x 3m log cabin as a workshop after having a large garage to frame in.
I've found this is an issue now, so I sort out the moulding and make sure it faces the correct way before taking it in and storing it, then when I lift it down to cut it is the correct way round.
pramsay13
Re: It's a mystery!
Postby drpeej » Sun Sep 17, 2017 4:32 pm
pramsay13 wrote:I have recently built a 5 x 3m log cabin as a workshop after having a large garage to frame in.
Glad it's not only me :Slap:
drpeej
Re: It's a mystery!
Postby IFGL » Sun Sep 17, 2017 4:52 pm
featurepiece wrote:Cut a little gap about waist height around the whole garage, hang the top bit from a nearby tree or high hedging.
If you do decide to go this route, I would also teather the top part of the shed to prevent it swinging.
IFGL
Re: It's a mystery!
Postby drpeej » Sun Sep 17, 2017 4:57 pm
IFGL wrote:If you do decide to go this route, I would also teather the top part of the shed to prevent it swinging.
Alternatively I could let the whole shed rotate and keep the moulding the same way round
drpeej
Re: It's a mystery!
Postby prospero » Mon Sep 18, 2017 1:23 am
There's too much of this going on. :evil:
It's not only moulding. I recently got a box of nails and at least 50% of them had the points on the wrong end.
But I managed to save the situation. I set them aside in a separate box and used them on the left sides of frames.
:lol:
Re: It's a mystery!
Postby Jamesnkr » Mon Sep 18, 2017 9:27 am
At 1.23am Prospero was worrying about which way round his nails sit...
Jamesnkr
Re: It's a mystery!
Postby prospero » Mon Sep 18, 2017 11:30 am
It gets worse.....
Just started a new box of screws and the points are OK but the heads are at the wrong end.
Aliens!!! :shock:
Re: It's a mystery!
Postby Jamesnkr » Mon Sep 18, 2017 12:14 pm
Ever had a box of Pozidriv screws where the screw-heads are at 45 degrees to normal - so they're like the St Andrew's Cross, rather than the St George's?
Jamesnkr
Re: It's a mystery!
Postby prospero » Mon Sep 18, 2017 5:29 pm
It's San Andreas' fault. It usually is. :Slap:
Re: It's a mystery!
Postby featurepiece » Mon Sep 18, 2017 6:26 pm
I once worked in tech support - call center stuff. We had a guy that, every time he was stumped, told the customer that their issue was due to the current heavy load of solar wave reflection. They were advised to leave things for a bit and try again later :)
featurepiece
Return to After Hours
  • Advertisement
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
