Twist/warp in frame!
Ask for and give assistance
Postby Bigfishsmallworld » Fri May 18, 2018 6:16 am
I've only just joined the forum and I'm new to framing. I have a problem with some of my frames in that despite the mitres being cut OK, when I assemble the frame in the underpinned, it gets a twist in it i.e. it doesn't lie perfectly flat.
I'm using a quality mitre trimmer, (maybe a Morso later) being very accurate to make sure lengths are cut exactly the same and using a Cassese CS79 foot operated underpinner.
the moulding length are straight so I'm struggling to determine what I'm doing wrong.
Any help greatly appreciated.
Bigfishsmallworld
Organisation: Hayfield Picture Framing Company
Interests: Play electric bass and acoustic guitar in rock band,caravaning, picture framing, hill walking, photography
Gunnar Computerised Mountcutters
Re: Twist/warp in frame!
Postby fusionframer » Fri May 18, 2018 8:24 am
Hi there,
If your frame is mitred at exactly 45" and lengths are exactly the same, (given your moulding is true) it then has to be pinning it that is the problem. It has to be one of those elements essentially.
How is the join. It might be snug at the top, but check the bottom of the join which should be as tight as the top. If not, then that will cause your frame to be twisted.
I have not used a cs79, so others may help with setup.
Nick
www.fusionframing.co.uk
fusionframer
Interests: framing
Postby prospero » Fri May 18, 2018 9:51 am
That's life as we know it. :cry:
Some lengths may appear straight but they can have twists somewhere.
However, if you are using a mitre trimmer then you must ensure the base of the moulding is flat to the bed. It could be the
shearing action of the trimmer is jiggling the moulding and not cutting a true track. These mitre trimmers are not meant to cut frames.
They are more for truing up pieces of trim around furniture and wotnot. In these situations the trim is not formed into a four-sided shape,
so any inaccuacies are not so critical.
My advice: Get a Morso. Good secondhand examples are always for sale at around £600-900 mark. About half new price.
You can very soon waste that value in moulding with inferior equipment.
It's not likely the underpinner is the culprit. When you join a frame any deviations either in the cutting or in the moulding itself will
manifest themselves on the last corner. If the last corner won't line up when you come to pin it then something is amiss.
*** There's a Morso in the Ads section right now. Looks in excellent nick. I'd buy it. :D
viewtopic.php?f=7&t=16444
Postby Bigfishsmallworld » Sat May 19, 2018 1:28 pm
Many thanks for your replies. I understand the comments about the Morso!
I am working from home in a space created from part of my garage. It’s approx. 3.5 mtrs long. Would I be able to fit a Morso in this space as the arms look quite long!
Bigfishsmallworld
Postby prospero » Sat May 19, 2018 1:41 pm
Placing Morsos is a tricky business, but with a bit of youknowwhat in the head department it's surprising where they
will fit. I theory, you need a minimum 17ft clear run. But, most of that is the 'run in' for a 10ft length. If you can contrive
to have the left side facing a door (or a window :P ) you only need about 7ft. You could saw a bit off the measuring scale if
you only do smallish frames. Best not to though. :roll: I've know people who've knocked holes in the wall.
Return to Help!
Picture Framer's Oracle
Members Map Header
Members Map
More info
Resources Header
Contact Forum Admin
Directory
Cove Box Designer
Download Designer
General supplies
Glass
Machinery
Mounts/Mountboard
Artists
Conservators
Prints
Software
Tuition
UK Medals
Framers Forum Live!
Support Header
Crimson
White
Green
Violet
Advertise Header
Forum Banner Ads
