Rose & Hollis Earth Pigment Paints.
GeoSpectrum
Post by GeoSpectrum »
Has anyone used the Rose & Hollis Earth Pigment Paints? I've just ordered tin to see what they are like, I'm thinking of using them for washes over a base colour to give a more aged look to some of my frames.
Re: Rose & Hollis Earth Pigment Paints.
Post by vintage frames »
I've never used these paints but you have the right idea to put them to use. If you want to give your paint an impression of age then a thin wash of some sort of umber-y colour will certainly do the trick. These things work best on a less is more basis. Subtlety is the watchword. Too much earth wash can deaden a colour. I'd be interested to know how you get on.
My go-to formula for this is ripple paint with a dollop of Raw Umber acrylic mixed in.
You can exp with different colours but I've found the effect is so subtle that the fine points of colour hardly matter.
If you apply a very dilute wash it will look different when dry. Apply pure white and it will appear grey.
Important to differentiate between a wash (opaque) and glaze (transparent). :wink:
They come in about 1 litre tins, if you are watering them down for washes, you won't be needing that kind of quantity per colour.
standenfineart
Organisation: Private
Interests: Private
Post by standenfineart »
GeoSpectrum
Thanks for the link. They look like nice range and the same as the Rose & Hollis paint as it turns out. Any thoughts on popular colours?
If I remember rightly, Rose and Hollis had some hand painted samples an A4 sized card. I think that you might not find it particularly easy to pick the favorite colours, I don't think there's a disappointing colour in the entire range.
